Hood Latch Bolt assembly part number?
Old 12-27-2007, 01:44 AM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
Default UPDATE! Parts not really available, but fixed. Hood Latch Bolt assembly part number?
My 93's hood keep popping up on the passenger side. I have adjusted everything in the assembly and latch section per FSM. I even put a cable in there and adjusted it all the way out, to make it tight, and I use the cable to pull the latch.
If anyone has ever dealt with this assembly and know the part numbers/pricing etc, I would appreciate the help.
Old 12-27-2007, 07:56 PM
steve40th
steve40th's Avatar
Well as I was driving down the highway and hit a few bumps I noticed the right side, which I have been having problems with, bounces up and down when I hit bumps. But it is adjusted so I cant move it down at all or pull up when I actually use my body weight to push the hood down.
So, could it be as simple as the springs are bad. I do open and shut this hood allot!
Old 12-28-2007, 10:13 PM
kize
kize's Avatar
I had a similiar problem. The main hood pin was worn on one side causing it not to stay latched. Replaced the main hood pin and all is all well.
Old 12-28-2007, 10:28 PM
steve40th
steve40th's Avatar
Are you talking about the pin that is inside the spring? I looked at mine and it isnt exactly flat.
Old 12-29-2007, 02:16 PM
tobijohn
tobijohn's Avatar
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Below in PDF format are the pertinent pages from the C4 Parts microfiche, if that's any help to you:
File Type: pdf
Old 01-07-2008, 11:08 PM
steve40th
steve40th's Avatar
I couldnt find parts to replace my hood pins etc as they are discontinued. So, A felllow forum member Jared, hooked me up with his OLD ones
Well you can see his OLD ones were in tip top shape compared to mine.
I will reuse my spring as it is the fat one. But look at the pin and you can see how mine was chewed up and not grabbing the latch. I hope this fixes it from popping up.
Old 01-07-2008, 11:19 PM
jsquared94
jsquared94's Avatar
Hope they work well for you, Steve!
Thanks!
Jared
To Hood Latch Bolt assembly part number?
Quick Reply: Hood Latch Bolt assembly part number?
