Solution To Ecm Problem!
Old Dec 29, 2007 | 02:22 PM
Brooklyn's Avatar
Brooklyn
Cruising
Default Solution To Ecm Problem!
I have a 1992 corvette and was experiencing problems. As I was driving my Security and ASR light would flash and cause my car not to start once it was turned off. I posted my problems on this website and recieved numerous responses suggesting to replace my ECM, but I also recieved one response suggesting me to top off my brake fluid. To replace the ECM would cost about $500, so I tried topping off my brake fluid. It worked!!! I have not had a problem with my car in months just because of this simple solution and I saved myself alot of money.
Old Dec 29, 2007 | 09:03 PM
VenkmanP's Avatar
VenkmanP
Old Jan 1, 2008 | 07:57 PM
Tom Piper's Avatar
Tom Piper
I'm certainly glad you solved your problem.
But, topping off the brake fluid would not have anything to do with the Security light -- that you can bet on.
My guess is, since the ECM is under the hood, cooler weather is what has given you a temporary solution.
When warm weather returns and the under-hood temperatures rise, I would not be surprised to hear your problem is back.
Tom Piper
Old Jan 2, 2008 | 01:51 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Tom Piper
Old Jan 2, 2008 | 01:57 PM
NEVRL8T's Avatar
NEVRL8T
Originally Posted by vinnies87
Old Jan 3, 2008 | 12:32 AM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
I have the same problemo...and the brake fluid was full...
To Solution To Ecm Problem!
