Shift Lights
Old Nov 27, 2001 | 11:32 PM
Charles Klein's Avatar
Charles Klein
Default Shift Lights
Can someone refer me to a maker of shift lights that are easy to install in a '96?
Old Nov 28, 2001 | 01:14 AM
AS84's Avatar
AS84
Default Re: Shift Lights (Charles Klein)
I just bought the autometer pro shift lite. Three wires and its pretty small in length and diameter. You can see it at autometers website....it looks pretty slick. You don't have to have any other components or anything else. The rpm pills slide right into it.
Old Nov 28, 2001 | 01:22 AM
jpee's Avatar
jpee
I feel real dumb... I had one in my 96 Camaro, & cant think of the name, but you can fine them in Jegs or Summit..
They all are easy to install .. 3 wires hot, ground, & one to the tac sending wire inder the hood, or under the dash if you can find it..
Old Nov 28, 2001 | 01:50 AM
jpee's Avatar
jpee
Default Re: Shift Lights (Red96Coupe)
Just remembered.. Autometer makes em.. check it out at http://www.jegs.com
Old Nov 28, 2001 | 07:25 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
You could also check out the Harlan shiftlite. For the $ I think you get a pretty good product. I like Autometer products but this shiftlite is small yet bright, doesn't require new "pills" to be bought if you want to change the activation point and LEDS are standard.
The direct link to the website to find info or order one is: http://harlan.sketchy.net/store/store.html
gs633 and a few others on the forum have these in their cars, Hutch has a good install procedure documented on his website: http://www.hashmarks.com/ShiftLight/index.html
Old Nov 28, 2001 | 08:07 AM
RichS's Avatar
RichS
Default Re: Shift Lights (Red 90 L98 Coupe)
I've had the Harland light for a year now and think it works great! Easy to mount in the A/C vent so it's out of sight till it lights up.
Old Nov 28, 2001 | 01:06 PM
Hutch's Avatar
Hutch
Default Re: Shift Lights (RichS)
I agree. I think the Harlan mini-shiftlite is the best unit out there. Its tiny enough that you can hide it most anywhere (see my install procedure, mentioned above, at http://www.hashmarks.com/ShiftLight/index.html) but plenty bright. The best part is you don't have to mess with those darn pills! Just throw a couple of DIP switches to set the RPM.
Nice to see that Harlan has a new website so maybe he's back into making these again. For awhile there he wasn't responding to emails according to a friend that's been trying to contact him for one. I see his price has gone up from $35 to $50, but its still a very good deal. :yesnod:
Old Nov 28, 2001 | 05:47 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
I have the Harlan light and it it's perfect.
Old Nov 29, 2001 | 02:08 AM
Charles Klein
Default Re: Shift Lights (Thumper)
Thanks, everyone. I wrote to Harlan and he said he can ship one of his lights in less than two weeks.
It looks that the Autometer pills go up in increments of 200. It's cool that the Harlan unit allows 100 rpm adjustments. Plus, I expect that my shift point will ultimately be alot higher - I would need a new set of pills.
Why are LEDs better? Is it because they light faster?
Old Nov 29, 2001 | 02:13 AM
scorp508's Avatar
scorp508
I have the Harlan light around here somewhere, had it for about 8 months, haven't installed it............ talk about lazy!! :D
To Shift Lights
