Reverse Lockout
Old Jan 9, 2008 | 09:15 PM
Black_Vette's Avatar
Black_Vette
Default Reverse Lockout
Reverse lockout assembly is damaged on my 86 Vette.
My question, is the lockout assembly one piece or is it two seperate pieces ???
The following is a link to a pic I found on this forum I just wanted to know is this all one piece or is it two pieces ???
http://forums.corvetteforum.com/show...everse+lockout
Old Jan 9, 2008 | 09:43 PM
mrc24x's Avatar
mrc24x
I went to the hardware store and bought a 1/8" SS rod that I cut to the correct length then bent the top 1/4" over 90 degrees and slid it into the black plastic "holder" in the pic. $2 and worked great.
Old Jan 9, 2008 | 11:24 PM
Black_Vette
Could you give me some clarification as to what you did exactly. My black plastic holder dosent have any spot to latch the quarter inch bend. How did you physically attach the rod to the slider???
Before you had trouble with yours do you know from the factory that if the black plastic holder is fixed to the rod or not???
Old Jan 10, 2008 | 09:32 AM
mrc24x's Avatar
mrc24x
Mine didn't even have a rod in it when I bought the car. The 1/8" rod fits pretty snug in the opening so I just bent over the top of the rod to hold it in place when you pull up to put it in reverse. Once I got the length I needed I put the top 1/4" in a vice (crushed it flat) and bent it over 90*. I don't have the tranny anymore so I can't take pics (sorry).
I'll try this from memory....
1)If the shifter is in the car just slide the SS rod into the holder until it bottoms out. (**w/ shift **** off and in reverse)
2) Move the shifter to N. Slide the rod down another 1/4"-1/2". Now you should have the rod down far enough to act like a "stop" and you shouldn't be able to put it in reverse w/ out raising the rod w/ the "trigger/holder".
3) If it won't go into Reverse while raising the trigger then you need to raise the rod a little to clear the stop.
4) Mark the rod when you have the right spot and cut it. I bent the top over but I guess you could epoxy it in the holder or whatever you want to keep it from moving.
FWIW, I adjusted my linkage after I added the stop and it made it feel like a new car.
Good Luck,
Matt
Old Jan 10, 2008 | 10:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You can see in his pic that the rod has a clip ring at the top. Is that what your missing ?? The **** just pulls the rod up to allow the shifter to go into reverse.
Old Jan 10, 2008 | 11:44 PM
Black_Vette
No I have the ring on top. I think I figured out whats going wrong all I need to know is how to you pull the rod out of the **** any ideas???
To Reverse Lockout
