ALTERNATOR Issue
Old Dec 22, 2007 | 08:41 PM
Chapindad's Avatar
Chapindad
Default ALTERNATOR Issue
I was going to replace the power steering pump. I unscrewed the bottom Alternator bracket bolt when I lift up the alternator to move it out of the way, when I noticed that the bottom of the alternator was still in place. Not sure how long it has been broke but it sucks. I go to advance to get a replacement and they give me one but all the electrical hookups are 180 degrees off. I am having a hard time finding one now. The ground wire is long enough but the 3 wire connector is too sort to move to the top.
So I have 3 choices:
1. Find the correct alternator and wait the time it takes to get it.
2. Cut the three wires and make extensions for them so that it is longer and can fit the top.
3. Take a part the new alternator and try and move the front 180 degrees so everything matches up.
What should I do? The first two I can handle but I have never taken a part an alternator to know if what I suggest is possible.
Thanks in advance for your input...
Old Dec 23, 2007 | 02:06 AM
Curveit's Avatar
Curveit
That simply isn't the correct unit for your car. You shouldn't have to "clock" it. Try another parts store
Old Dec 23, 2007 | 02:15 AM
Demonic85's Avatar
Demonic85
sounds like they didnt know what they were doing.
Old Dec 23, 2007 | 03:06 AM
RRT vette's Avatar
RRT vette
Sounds like they sold you the wrong alternator. You can also have the old one rebuilt.
Old Dec 23, 2007 | 04:02 AM
86GoldProject's Avatar
86GoldProject
yeah keep looking around, I got a reman from autozone not too long ago and it fit just like the factory one..
Old Dec 23, 2007 | 06:44 AM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I agree with everyone else here. There should be a lot of parts places that know what they are selling you.
Last ditch effort will be to take it apart and rotate it to the correct psition.
Old Dec 23, 2007 | 09:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I bet it would take less time to remove the 4 bolts and spin the front half 180*, that it would to return it and find another.
Old Dec 23, 2007 | 10:10 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Return it and get the correct replacement part.
Old Dec 23, 2007 | 10:34 AM
Chapindad's Avatar
Chapindad
So it is possible to rotate the front 180 and it still line up and work. I am going to order one today from autozone but if it has the same problem then I may try and rotate it or just make some extentions. I just want to drive my car!
Old Dec 24, 2007 | 03:35 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Old Dec 24, 2007 | 05:21 AM
davidnclearlaketx's Avatar
davidnclearlaketx
Go to O'Rilley auto parts and get the correct one that has the lifetime warranty! I'd steer clear of AutoZone parts. Not the best quality from what I've seen. You get what you pay for.
Old Dec 24, 2007 | 08:52 AM
ineVETTEable's Avatar
ineVETTEable
Reclock to the factory position. 4 bolts & 20 min.
Old Dec 24, 2007 | 09:23 AM
Muffin's Avatar
Muffin
True dat. For those of us with early C4s it is wise to take your old alternator with you when you get a new one. Saves on a core charge trip and it insures you are getting the correct unit.
Old Dec 24, 2007 | 09:41 AM
Chapindad's Avatar
Chapindad
This is where I got the last one and the casing broke off the bottom. And to be honest I was planning on taking it back to deal with them but I have had nothing but had trouble with their customer service. It seems the store I go to hires idiot wannabe street racers, who only want to race me everytime I go in and have no desire to actually do their job.
Old Dec 24, 2007 | 10:21 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Warranty?
If they sold you the original then it is time to go see them and force them to replace it. If they give you a hard time, ask for the manager, then the regional manager. The regional guy, if it gets that far, will satisfy your warranty claim. I would press this point. If they sold it to you with a warranty... take it back and make them do the work. Don't let them off the hook.
Old Dec 24, 2007 | 07:43 PM
Brimis's Avatar
Brimis
Have the original alternator rebuilt.
Old Dec 24, 2007 | 09:14 PM
Curveit's Avatar
Curveit
Do you have a rear brace from the Alt. to the head or exhaust manifold? It can break the case if you don't have one.
To ALTERNATOR Issue
Old Dec 24, 2007 | 09:27 PM
redrose's Avatar
redrose
Default No
86 and newer use CS series alternators...can NOT ''clock'' these units...85 and older SI-xx series can be ''clocked'', but the newer CS-xxx alts have less internal clearance and ''simplified'' machining during manufacture that does not permit assembly of the halves in other than original orientation.
Old Jan 10, 2008 | 11:56 AM
Chapindad's Avatar
Chapindad
To finish out this thread.
I got a new alternator from Autozone, Duralast Gold, and of course the connector was a problem, so I purchased a new connector from Autozone for $6.99 and cut off the old one, which had broken anyways, and soldered a new one on to it with shrik wrap tubing. If I did it again I would have used two pieces of the shrink tubing. I now have plenty of clearance and the connector is sound once again.
Old Jan 10, 2008 | 11:55 PM
Siveck's Avatar
Siveck
I did that twice before I realized that the rear brace is necessary.
