LS2 into C4
Old Jan 22, 2008 | 07:57 PM
  #41
k_ljones's Avatar
k_ljones
Originally Posted by 69Myway
That is a good question. We have all the parts on the shelf ready to go. There is a significant difference in the L76/L92 head/intake package, and the cam has a ton of bump.
I am a tad apprehensive about this portion of the project as the car runs so well right now and is plenty fast. GM rates the performance package at 480 hp around 6,500. That is enough to twist the car in two without other major mods to support. If it isn't driven hard all the time, it won't matter. However I know gas mileage will suffer and it will have a thump idle, and possible surge or other issues that are common when you push the envelope.
So - we don't have it on the calendar yet. We may put it all in to see what it does, dyno it out - drive around, then remove the parts in favor of the LS2 stuff.
The only thing I have to compare it to is my 69 Camaro. I have a SLP Stage III modified LS1 in that car. It is a fairly radical (for street use) cam, LS6 intake, highly modified LS6 heads - headers, 36# injectors...etc. While the car will blister the pavement and put a smile on your face that lasts all day...it suffers from rough idle, etc. It is a drive by cable and from time to time will stall as the IAC has trouble compensating for the air needs (not cool). However, it still gets 25 mpg on the highway and 16 in town (I drive the Camaro every day right now).
So...we will see.
Earlier in the thread I had said that I wanted to be sitting at 475 rwhp that setup would make it come pretty darn close. If you think it may cause other parts of the car to fail then maybe it's time to look at the goals I'm trying to achieve with the project. Taking into consideration how streetable, (idle, mileage) dependable, and performance oriented the car is now I'm not sure I would want to make the extra jump. How do you think the transmission will handle the extra hp? Rear end? I'm very interested to see how the new mods turn out.
Old Jan 22, 2008 | 10:21 PM
  #42
Speed Hound's Avatar
0Speed Hound
Former Vendor
Neither your trans nor your rear end will take that type of power. You'll have to upgrade to a dana 44 to have a chance. The trans can be built to handle the power though.
You can reach 475 rwhp easily. See how you like this powerband http://ls1tech.com/forums/showthread.php?t=807945
To me it's a we bit peaky. I prefer a broader more flat torque curve btu that's me.
Old Jan 23, 2008 | 02:11 AM
  #43
Slalom4me's Avatar
Slalom4me
FWIW
The LS3 crate engines recently landed at SDPC. Part # 19201992.
$6195.00. Click image for link
Old Jan 23, 2008 | 05:04 AM
  #44
69Myway's Avatar
69Myway
Old Jan 23, 2008 | 07:40 AM
  #45
0Speed Hound
Former Vendor
mmmmm LS3. That's nothing but an LS2 with the L92 heads and L76 intake. Not a bad way to start a build up
Old Jan 23, 2008 | 11:01 AM
  #46
69Myway's Avatar
69Myway
Those are the heads/intake I have right now waiting to go in our car - but there is the addition of the ASA hot cam...and a matter of .2 liter increase for what that is worth.
Old Jan 23, 2008 | 01:54 PM
  #47
Demonic85's Avatar
Demonic85
I've already decided that if my engine blows up, i'm dropping in some kind of LS engine.
Old Jan 23, 2008 | 02:01 PM
  #48
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Very expencive to do right.
I got a quote of over 20G for the conversion, parts and labor, that was a super price for what I was getting but out of my price range.
Old Jan 23, 2008 | 06:35 PM
  #49
0Speed Hound
Former Vendor
That's a wee bit too high actually. I wouldn't charge that much to do this conversion. However, the main components will make a huge difference in price. For instance, new engine and trans or used? New accessories components or used. You can definitely have it done for less than 20k.
Chris, you're right, I always forget the LS3 is a 6.2. Every little bit counts I guess.
Good choice Demonic
Old Jan 23, 2008 | 07:59 PM
  #50
k_ljones's Avatar
k_ljones
Originally Posted by Slalom4me
FWIW
wow didn't think they were going to be priced that well not a bad deal for the extra horsepower. Should have the same outer dimensions for the most part right?
Old Jan 23, 2008 | 08:14 PM
  #51
k_ljones's Avatar
k_ljones
Impressive numbers but I agree with you I prefer the broader curve. I really like the curve on the LS3. I like the extra hp #'s seems like a pretty good base for a good build up.
Old Jan 23, 2008 | 08:20 PM
  #52
k_ljones's Avatar
k_ljones
Thats where I can save a lot of money on labor by doing it myself. All the research is pretty well done on the installation, just some time and skinned knuckles.
Old Jan 24, 2008 | 07:10 AM
  #53
0Speed Hound
Former Vendor
All LSx engines are virtually the same externally. The plates I designed to hold an LSx engine into a L98 C4 will hold any of them, even the LS7 correctly. Same thing with the Melrose headers. They will bolt up and work with all of them. I wouldn't recommend them on the LS7, but they will work for that engine.
I also received a call from a gentleman in Illinois that has done a number of these installs himself already. His latest is an LS6 in a 92 vette. He said he was able to use the C5 motor mounts and the mounts dropped right back into the holes on the frame that hold the LT1. These cars are road raced so they are gutted, but he indicated that the LSx AC will fit in it's stock location with the engine mounted using C5 mounts. The Melrose headers fit no problem he said. So you LT guys still have huge wiring issues to over come but you've got some things working for you.
Old Apr 24, 2009 | 10:48 AM
  #54
Greenmonster138's Avatar
Greenmonster138
1st Gear
My question is what is done with the C-beam to mount the T-56. From what I have read, you just have to make the stock holes into an oval shape and notch it. I'm also guessing people are modding the stock driveshaft? Not sure if it has to be shorten or made longer. All of this done for a Dana44 C-beam and driveshaft. I heard someone say that the shifter location isn't in the right location with the T-56. Just trying to get all the info I can.
Old Apr 24, 2009 | 11:02 AM
  #55
Demonic85's Avatar
Demonic85
Good choice Demonic
Thanks i've already started saving money for the project as i'm not going to mod my L98 any further. My goal is a LSx engine pushing roughly 450 to the wheels with a 6 speed behind it. Already have the rear, Ford 9 inch
I gotta be honest, this swap doesnt look hard at all. Just takes some time to get it all right.
Old Apr 24, 2009 | 12:19 PM
  #56
j-stingray's Avatar
j-stingray
im doing an ls2 swap in my 1986 vette but its gonna be drag raced for most of the time
the speed hound plates look good so Ill look in to that one for sure
im going for the edelbrock intake with the msd box and a AED carb setup
I the engine i got was a warranty swap for a 2005 vette
I opened it up and some lifters broke and the cam is toast
only thing now is ,how do I get the balancer bolt loose
to loosen its counterclockwise right?
I tried a electric wrench from Hitachi that they use for trucks but it don't even move!! [ so advise anyone? ]
thanks jeff
some pics of the engine are here:
http://s18.photobucket.com/albums/b1.../MY%20RACECAR/
Old Apr 24, 2009 | 02:40 PM
  #57
0Speed Hound
Former Vendor
You'll need to move the engine forward over where my plates have the engine sit or you'll have to build an offset shifter when using the T56. My plates holds the enign in basically the stock location.
You'll have to make an adapter bracket to go from the Cbridge to the T56. I don't know of anyone that already makes one.
To LS2 into C4
Old Apr 24, 2009 | 02:43 PM
  #58
0Speed Hound
Former Vendor
thanks jeff
CCW off, yes. Use a 1/2" pnuematic impact gun set at 120psi. Should come off after a few seconds. You'll need a 24mm impact socket though. Might be able to get by with a normal socket. The other option is to connect something to the crank shaft in th eback and leverage there while using a long braker bar on the front. The torque on the bolt is based on angle but supposedly the conversion the foot-pounds puts it well over 200 ftlbs.
Old Apr 24, 2009 | 02:46 PM
  #59
0Speed Hound
Former Vendor
It's not hard really. It's just very time consuming because of all the little things that have to be swapped. The electric dash is a pain to deal with. Getting the wiring under the hood separated from what stays and what goes is too. Then you have to deal with the wiring to the PCM. Take your time and you're going to be fine. The more fabrication you can do yourself the better.
Old Apr 25, 2009 | 01:27 AM
  #60
j-stingray's Avatar
j-stingray
thanks man
ps do you send your parts to europe too?
thanks jeff
