LS2 into C4
Old Apr 25, 2009 | 02:34 AM
  #61
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Guldstrand fitted a 93 with a ZF transmission. I posted an article here.
Old Apr 25, 2009 | 07:47 AM
  #62
VettAid's Avatar
VettAid
6th Gear
Very nice looking!
Old Apr 25, 2009 | 07:56 AM
  #63
Speed Hound's Avatar
0Speed Hound
Former Vendor
Originally Posted by j-stingray
thanks man
ps do you send your parts to europe too?
thanks jeff
Absolutely. I typically send everything USPS Priority International. It's pretty quick and inexpensive.
Old Apr 26, 2009 | 02:59 AM
  #64
j-stingray's Avatar
j-stingray
OK send me the C4 LSx swap plates
do you also have the original motor mounts for sale ?
because i need a set of those too?
give me your email and i pay pal you the money and the address
PS i live in Holland [the Netherlands] Europe
thanks jeff
Old Apr 26, 2009 | 08:07 AM
  #65
0Speed Hound
Former Vendor
I PM'd you Jeff
Old Dec 14, 2009 | 12:57 PM
  #66
gaeecho9r's Avatar
gaeecho9r
engine 2 k lol try 6-7k ls2 0r 3 create motors...........your putting in a used engine on a hotrod swapout???????????????????
Old Dec 14, 2009 | 10:00 PM
  #67
Mojave's Avatar
Mojave
You're, not your.
What's wrong with used engines? Plenty of used engines out there that run just fine.
Old Dec 16, 2009 | 12:47 AM
  #68
Crepitus's Avatar
Crepitus
http://paceperformance.com/index.asp...&ProdID=148513
Old Dec 16, 2009 | 12:57 AM
  #69
Crepitus's Avatar
Crepitus
Or this
http://forums.corvetteforum.com/c5-p...rged-rods.html
Old Dec 16, 2009 | 10:01 AM
  #70
Bob86ZZ4's Avatar
Bob86ZZ4
I've got a th400 manual valve body with a Gear Vendors overdrive in my '86. I did somewhat of a write up on my install here: http://temp.corvetteforum.net/c5/bob...nversion.shtml
I really like my custom made 2 piece torque arm. It's held up great after much abuse.
I don't split all the gears under normal use. It's just too much messing around pushing the button all the time and trying to time it with manually shifting the th400. I do a fair bit of autocrossing. The gv is great for giving me half a gear jump in areas on a coarse where I don't have enough room to the next cone for a full gear change. I also use the GV around town if I'm cruising and want a bit more gear but not a full one up. I'm very old and don't have to be clutching all the time so I like this setup in that respect.
Would I do it again? I don't think so. I wish I had even a higher ratio for highway cruising and the .78-1 final is just not enough. I'd go ZF-6 if I was you. Even the 4l60e is only .70-1 isn't it?
