Camaro headers
Old Nov 29, 2001 | 07:22 PM
Jedi404's Avatar
Jedi404
Default Camaro headers
Would they fit on an 86 vette?
Old Nov 29, 2001 | 07:41 PM
RichS's Avatar
RichS
Default Re: Camaro headers (Jedi404)
I doubt it without beating the heck out of them :D
[Modified by RichS, 6:42 PM 11/29/2001]
Old Nov 29, 2001 | 11:18 PM
vader86's Avatar
vader86
if the 86 has cast iron heads, my first guess would be yes. If aluminum, then no. The Z28 had an L98 with iron heads, same as the early 86's.
Old Nov 30, 2001 | 01:11 AM
ZBRA's Avatar
ZBRA
No. The Corvette dumps from the center and the Camaro dumps in the back.
Old Nov 30, 2001 | 05:54 PM
Jedi404's Avatar
Jedi404
Default Re: Camaro headers (ZBRA)
dumps?
Old Nov 30, 2001 | 07:59 PM
ZBRA's Avatar
ZBRA
dumps?
Where the exhaust exits the manifold or header/where the exhaust pipe connects to the manifold or header.
The factory exhaust pipes on the Corvette bolt to the factory manifold dead center of the engine (front to back) or under the #3 and #5 (driver side) and under the #4 and #6 (pass side) exhaust ports.
I you attempted to do this on the F-body (camaro/firebird), you would hit the front crossmember that goes under the motor. Therefore, the F-body manifolds exit toward the back of the engine where it bolts to the transmission.
Old Nov 30, 2001 | 11:17 PM
RichS's Avatar
RichS
Default Re: Camaro headers (vader86)
It don't matter if the car has alum or cast heads for the proper header to fit. It makes no differance.
To Camaro headers
