Porting Plenum??
Old Nov 29, 2001 | 10:54 PM
Gregory VanLare's Avatar
Gregory VanLare
Default Porting Plenum??
I've read many of the threads about mods and many of them discuss "porting" the plenum, what exactly does this entail and what tools does it require? I'm taking my 85 apart to replace the fuel injectors and am wondering if this is something I can do while it is apart. If it needs to be sent out I would consider that also depending on the cost. Can anyone help?
Old Nov 29, 2001 | 11:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Porting Plenum?? (Gregory VanLare)
My method is on my site.
Old Nov 30, 2001 | 02:29 AM
pablocruise's Avatar
pablocruise
Just for info: when I went thru this, extrude honing was mentioned. I researched it and found it was not worth the $. A quote of 650.00 was given for doing the upper, runners, and lower base. I did hand port my upper and lower stock peices. I ruined my lower base by porting too much. My suggestion would be to be conservative when removing material especially #5-#7 intake tracts. Did you see some of my previous posts on this topic?
Old Nov 30, 2001 | 06:27 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I ported my plenum with a kit from Summit Racing. It's a small kit for Porting and polishing. All I used was a good variable speed drill and plenty of time & patience.
Old Nov 30, 2001 | 09:55 PM
Romeo Barrera's Avatar
Romeo Barrera
I've got pics on my website.
To Porting Plenum??
