fuel injectors
Old Jan 20, 2008 | 06:53 PM
vett40's Avatar
vett40
Default fuel injectors
need help
does any one know what stock fuel injectors on a 93 lt1 put out for pressure i am in the middle of a winter project that requires 30#injectors i am wondering if i can just increase the fuel pressure with an adjustable fuel regulator
Old Jan 20, 2008 | 07:11 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Stock is 24 # IIRC. You cannot just increase fuel pressure. You will need 30 # injectors.
Old Jan 20, 2008 | 07:19 PM
STL94LT1's Avatar
STL94LT1
What is involved in your winter project?
You can increase the FP and get a little more fuel from your stock injectors. I'm running ~375 rwhp on stock 24's. But, my fuel pressure is turned all the way up.
vett40's Avatar
vett40
thanks for the infor
Old Jan 20, 2008 | 07:25 PM
vett40's Avatar
vett40
i have the le2 package from elliott's portworks head work, cam , long tube headers no cats 3200stall convertor 3.54 gears 58mm tb calls for 30/36lbs injectors
Old Jan 20, 2008 | 07:31 PM
STL94LT1's Avatar
STL94LT1
I'm running CNC ported heads, 224/230 605/622 cam, EM long tubes, 52mm TB, 4.10 gears, ect...ect..., and the stock 24's.
Old Jan 20, 2008 | 09:14 PM
Kevin Woods's Avatar
Kevin Woods
Originally Posted by vett40
...........i am in the middle of a winter project that requires 30#injectors i am wondering if i can just increase the fuel pressure with an adjustable fuel regulator
You can always go full blast on fuel pressure.......but it's smarter to have a small bit more injector than to have a lot more fuel pressure......from a tunability stand-point, anyway.
Do the 30 pounders .
KW
Old Jan 20, 2008 | 11:55 PM
comp's Avatar
comp
Old Jan 20, 2008 | 11:59 PM
STL94LT1's Avatar
STL94LT1
KW
If you're not on a strict budget, upgrade the injectors. Even though I've been running the stock injectors with my heads/cam combo for over five years. I plan on upgrading the injectors this spring to the 32# Racetronix.
Old Jan 21, 2008 | 08:55 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I believe the stock Multecs are 22 lbs. in a 93...if you get up near 100% duty cycle you need to go larger...
Old Jan 21, 2008 | 11:43 AM
BADDUCK's Avatar
BADDUCK
IIRC the last year for 22 LB Multechs was 1991 or 1992.
Old Jan 21, 2008 | 01:59 PM
vett40's Avatar
vett40
thanks for all the help guys . new injectors will be order
To fuel injectors
