Personally......If your valvetrain and heads can only accept .500" lift or so, then I'd guess it's OK .
Personally, though......If I were doing a cam swap with that much duration, I'd give it some heads that could take more lift and make the swap worthwhile!
Since you asked.............
KW
6000 RPM should be no problem. I have a CC flat tappet Extreme Energy cam in a motor from a '72 Nova SS that I totaled (sob), that had 224*/230* duration and .477"/.480" lift on a 110 LSA that would pull to 6000 all day. Made great power in a blueprinted 353 with puny World Products SR Torqer heads and 750 AFB style Edelbrock carb on an alum., dual plane manifold. Still have it and intend on finding out what it will do in the 1/4 in a '70 Nova my son is prepping for race only. Good luck w/your plans.
That lift would be Ok with stock heads, youre only gonna get so much air through them anyway.
Dont know about tuning and the 110 LC, maybe a tuner could tell you more.
I have a comp xr276 hyd roller on a 114lsa that is just a screaming cam, idle is great, so is the power and it's passable. You would need to upgrade springs but i would suggest a heads and cam package if i were you. Buy some AFR 180's and turn the cam up.
some mixed responses, The lobe separation worries me but from what I read lower LSA creates a peakier torque curve that comes earlier. If it comes too early for me I guess I can degree the cam and retard it a bit.
I wish I had the money for heads I'll see what I can do in the summer time in that case, but until then I just need a cam for the stock heads, thanks.
as for stock cam here is one from '87 (they have roller cams so their lift is probably set higher than '86)
202/207
.404/.415
114.5
Just ordered the comp cams one so we'll see how well it does in real life.
With only 60 degrees of overlap, its only slightly larger (overlap-wise) than the popular hydraulic rollers cc 305 (55 degrees) and cc 503 (54 degrees).
It is quite a bit smaller than the cc 306 (74 degrees)
I think it is milder than the 0.050" duration numbers suggest.
It appears to be a reasonable choice and a mild one at that.
the stock 86 flat tappet specs are on my site, but its very close to the 87s roller specs
I'd go for more lift with the cam choice, but I understand budget issues. Later on after you pick some better heads, you might want to consider tougher springs and go to 1.7RR.
You will absolutly love a cam on a 110lsa. You are right, it gets you in the power curve faster. Talk to a tuner first to find a guy whos confident in tunning it. I have a cam 215/224 on a 110lsa. Lift is .333 Multiply that by 1.6 for the roller rockers and you get .532. Small cam but pulls hard to 6300 rpms. Go to the track and youll see all the high powered muscle cars are using even tighter lsa. Not to mention the note you get from a 110 cam. Listen to mine in signature. Mine idles at 800 and there is no surging at all.
sounds good to me you must have fun with that car!
I was nervous about the 110lsa. Did lots of searches to find out more info and was pleasently surprised by the power and sound. Bark and bite! Good luck
From what i understand tighter LSAs are much hard to make pass emissions. Anyone know the details on this?
Well overlap creates hydrocarbons, but helps with Nox.
Anyway. to the OP:
I think that, rather than taking advice from folks who have not used that exact cam, folks should talk to people who have. (which isn't me, but I almost bought one a few years ago). Search on TGO. Lot of guys have used that cam. I know one guy who liked it on his 400. I know another guy (traxion) who did not like it on his 350. The rest you'll have to pick apart.
It does seem to have some pretty quick ramps for a flat tappet cam.
With a only a 6 degree spread and junk heads, I'm not sure it would be the cam I'd chose for your setup.
