valve cover, alternator clearance
Old Jan 25, 2008 | 05:38 PM
vett40's Avatar
vett40
Default valve cover, alternator clearance
this must have happen to somebody else. installing roller rockers on a 93 lt1 stock valve covers not tall enought. i order tall valve covers now alternator won,t fit right hits covers i looked up lt4 valve covers because i thought they came with roller rockers but they have the same part# as the 93 does . any suggestions would help
Old Jan 26, 2008 | 08:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did you investigate what was causing the interference on the stock covers ??
I have the worlds biggest, fattest roller rockers and made them fit into my factory covers(L98). (Trimmed drip tabs, trimmed sides of bolt towers, squished baffles.)
Tall valve covers may also give you grief with the wiper motor cover.
Old Jan 26, 2008 | 10:05 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
There's no standard for "tall" valve covers. Some are as much as 1.5 inches higher.
Pro Form makes a set that's only 1/4 inch taller than stock, that should do the trick. Summit has them.
Old Jan 26, 2008 | 06:15 PM
DVNCI's Avatar
DVNCI
When I put my ProForms on I had to grind the hell out of the back of the alternator.
Old Jan 26, 2008 | 07:31 PM
mcnulty95's Avatar
mcnulty95
I also had to shim the alternator bracket about a 1/4 inch.
Old Jan 26, 2008 | 08:31 PM
FD2BLK's Avatar
FD2BLK
What ever covers you d3cide to go with have to have a notch for the Alt. Many of the covers out there for LT1's have the notch on the wrong cover. Not a huge deal but if you decide to go with them you will have to reroute the PVC vent and of course do what ever trimming needed for the R/R's.
Old Jan 26, 2008 | 09:12 PM
jsup's Avatar
jsup
LT1s must be different. I just wanted him to know that "tall" means different things and that there may be a solution.
Old Jan 26, 2008 | 09:43 PM
DVNCI's Avatar
DVNCI
Probably so, that wasn't directed at you, just FYI for him.
Old Jan 29, 2008 | 06:16 PM
vett40's Avatar
vett40
thanks for the help guys i will do some reseach let you know how i madeout
Old Jan 30, 2008 | 09:39 AM
BerniesVette's Avatar
BerniesVette
I had to shim the alt. bracket up until it cleared the valve covers. I also reinforced the front part of the alternator bracket using a strip of metal bolting it to the alt and its bracket. Sorry I didn't do pics.
Bernie
Old Jan 30, 2008 | 08:08 PM
vett40's Avatar
vett40
after checking it out closer you where right it was hitting the drip tabs machine them off they fit great thanks again
To valve cover, alternator clearance
