Steering Pump Problems
Old Jan 26, 2008 | 10:02 PM
lead_foot's Avatar
lead_foot
Default Steering Pump Problems
While running some road course laps my power steering seemed to slowly go away. It's now making some nasty noise.
Does anyone know if someone makes a performance power steering pump or someone who rebuilds them for performance applications.
Apprecite any ideas.
Old Jan 26, 2008 | 10:04 PM
comp's Avatar
comp
do you have a cooler ???
Old Jan 26, 2008 | 10:26 PM
Sidney004's Avatar
Sidney004
The 96 has a cooler. How many miles on your car? I had the same thing happen to me on my 94. Be sure to check the basics first and that is fluid level. Any loss of fluid level is pointing to a mechanical problem. I assumed the worst(prior to checking my fluid levels) and it was a pinhole leak in the cooler. My car has 70,000 miles, an original rack and over 60 hours track time. Here is a link for an interesting rack if it turns out yours is toast.http://cgi.ebay.com/ebaymotors/CORVE...2em118Q2el1247
Old Jan 27, 2008 | 08:29 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://www.turnone-steering.com/index.html
Old Jan 27, 2008 | 08:34 AM
kalister1's Avatar
kalister1
Maybe you can change the pulley to SLOW down the pump?
Old Jan 27, 2008 | 08:37 AM
Iroc57's Avatar
Iroc57
Originally Posted by AGENT 86
Who'd of thunk it....
A performance power steering pump? I never saw such an animal.
Good link
Old Jan 27, 2008 | 09:49 AM
RichS's Avatar
RichS
Turn-one pump and DRM line kit. It will end all your power steering problems.
Old Jan 27, 2008 | 07:38 PM
KCHOTBOAT's Avatar
KCHOTBOAT
I went added a turn one pump last summer and works great. I burned up two pumps in one month before the turn one.
Old Jan 28, 2008 | 11:08 AM
lead_foot's Avatar
lead_foot
Thanks guys for all of your info. Fluid level was OK. No leaks that I can see. Car only has 15k miles on it. But it is 11 years old. I check into those products once I find out for sure what the problem is.
To Steering Pump Problems
