where does wire connect?
Old Jan 27, 2008 | 10:48 AM
rithsleeper's Avatar
rithsleeper
Default where does wire connect?
87' L98 - I am just asking about the single black prong wire in pic. It comes out of the EGR Valve.
http://www.putfile.com/pic.php?img=7504295
Old Jan 27, 2008 | 11:31 AM
chucks88's Avatar
chucks88
That one connects to a wire located behind the passenger side head. You may have to fish around for that one a bit.
Old Jan 27, 2008 | 02:14 PM
rithsleeper
Ive been looking, is it on back of engine? or side. give me a hint. is it comming out of bunches of wires?
Old Jan 27, 2008 | 06:07 PM
chucks88's Avatar
chucks88
Behind the passenger head coming from behind the engine...it could be hidden by the wires going to your distributor.
Old Jan 27, 2008 | 06:54 PM
86PACER's Avatar
86PACER
I've seen that thing before but I honestly can't remember for sure.
Old Jan 27, 2008 | 07:16 PM
wa4ky's Avatar
wa4ky
Acct suspended by request 12 Dec 2012
I have the plenum off my 89 right now and I just went out to look. I don't see a single wire in the location you show on my car. At least I havent found it. I can tell you that I have no wire of anykind running off my egr VALVE is that is what you are referring to. The wire you show doesnt look long enough to reach to the back of the head though. Not much help here I guess but I will take a better look tomorrow with more light and see if I can spot mine.
Good luck!
Gary in Louisville
Old Jan 28, 2008 | 09:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There are no wires on the EGR valve. Can you take a pic of it's origin and straight on looking at the connector face.
Old Jan 28, 2008 | 11:02 AM
KeyWestJack's Avatar
KeyWestJack
Is he referring to the egr solinoid? If so it is located up almost behind the the top rad hose housing (on the intake manifold).
Old Jan 28, 2008 | 11:49 AM
staugur's Avatar
staugur
looking at the photo you have posted the egr solenoid seems to be removed and anyway there's only the double connector shown in the pic that goes to it.the egr valve has no electrical connector only one vacuum line.I believe what your looking at is the connector for the AIR system control valve(diverter and check valves)which is also missing in your photo.
Old Jan 28, 2008 | 02:06 PM
chucks88's Avatar
chucks88
I thought that even though he said EGR valve, he was actually taking about the EGR tube
To where does wire connect?
