9th injector location HELP
Old Jan 27, 2008 | 02:36 PM
ronman327's Avatar
ronman327
Default 9th injector location HELP
Still have the gas smell can't find the leak. traced the lines to tank and checked for leaks in tank. Also can't find the charcole can if it's there I cnn't find it.
Old Jan 27, 2008 | 02:45 PM
RRT vette's Avatar
RRT vette
What year Corvette?
The 9th injector or cold start injector is located on the driver side between the front set of injectors and the rear set of injectors. A tube coming from the rear of the fuel rail wraps around the rear of the runners and goes to the cold start injector.
The EECS or charcoal canister is located where the drivers side headlight is when the hood is closed.
Old Jan 27, 2008 | 02:54 PM
ronman327's Avatar
ronman327
thanks will look
Old Jan 27, 2008 | 06:36 PM
rodj's Avatar
rodj
May not be fuel leak.Vent lines to canister get blocked so fuel vapours are vented from tank giving strong smell.
When you find canister disconnect tank vent line and see if you can blow through to tank
To 9th injector location HELP
