1994 Brake pedal hard
Old Jan 28, 2008 | 02:20 PM
Sailfish40's Avatar
Sailfish40
Default 1994 Brake pedal hard
I read a thread some time back that had over 1000 pages of comments on the cause and fix was for this problem. To be honest I was more confused after reading most of the replies than I was in the beginning. Obviously not all C4's are equal and what applies to one year does not apply to another.
first question, 1994/C4, OBD-I or OBD-II?
second, what pins to short to see the codes and clear them?
I will start with this and then take it from there..
Old Jan 28, 2008 | 02:28 PM
kalister1's Avatar
kalister1
94 is OBDI, but i think they started using the OBDII connector before 96? That's all I can add, I have a 93.
Old Jan 28, 2008 | 09:50 PM
pcolt94's Avatar
pcolt94
94 is OBD I. It has a OBD II connector. Connect pins 4 (ground) and 12 to initiate on board diagnostics (codes). It is a 16 pin connector.
To 1994 Brake pedal hard
