Battery replacement
Old Jan 29, 2008 | 05:17 AM
Putter's Avatar
Putter
Default Battery replacement
It appears that it is time to replace the battery in my 90 Vette. I would like input as to the type of battery that members have had success using. It is at least 7 years old.
I only put about 2500 miles a year on the car, so it sometimes sits for a few weeks at a time.
Are the small bolts replaceable that are used on side post batteries. My positive is slightly chewed up from a previous battery replacement before I purchased the car. Is so, is there a trick to getting them out?
Thanks for the input
Old Jan 29, 2008 | 05:52 AM
metal tech's Avatar
metal tech
The small bolts are an easy swap. Autozone & others sell replacement bolts in the battery section. You'll notice the new bolt has a washer looking area to it. Take a med-small screwdriver and pry the old bolt out of the battery cable from the hex side, it'll work it's way past the plastic/rubber holding it in. Then pop the new one in there, you're done.
Old Jan 29, 2008 | 01:24 PM
Steve20's Avatar
Steve20
the NAPA battery in my 95 lasted almost 4 years. Car was stored Oct-April no battery tender used. Just replaced the NAPA with an Autozone Gold
Old Jan 29, 2008 | 01:54 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I have an OEM Delco which is now 7 years old and going strong. The key is you must have a battery tender which, if properly used on a regular basis, will extend the life of your battery for many years. You might try a tender on your current battery for a month or two before you throw in the towel and but a new one. Here is a pretty good one http://batterytender.com/product_info.php?products_id=2.
Old Jan 29, 2008 | 02:26 PM
86PACER's Avatar
86PACER
Yes, they are replaceable. No trick, just disconnect from battery and pop them out. I picked up a new set at Kragen. My old ones where almost rounded off.
Old Feb 2, 2008 | 12:46 AM
85corvettekws's Avatar
85corvettekws
ive had much sucess with optima-a little pricey, but after replacing the battery you'll not regret putting in a longer lasting battery
Old Feb 2, 2008 | 07:50 AM
JackDidley's Avatar
JackDidley
Driving mine daily, I got 8 years out of an AZ Gold, so thats what I got again.
To Battery replacement
