L98 preformance
Old Jan 30, 2008 | 02:00 AM
colinwashere51's Avatar
colinwashere51
Default L98 preformance
How hard is it to get a L98 to 350 horsepower
And would it cost a whole lot?
Old Jan 30, 2008 | 03:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
Cost?? With a name like Colonwasher Id be worried about the hours and conditions youd have to work with .
J/K....Seriously, 350 is achieveable depends how good you are with a wrench.
Old Jan 30, 2008 | 07:54 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Easy if you have a spare $5000.
Old Jan 30, 2008 | 08:17 AM
JackDidley's Avatar
JackDidley
Coffee spew.
It will take heads, cam amd intake to get that horsepower. I will take a guess and say it will take $4000 plus labor.
Old Jan 30, 2008 | 09:11 AM
jeffyc's Avatar
jeffyc
i believe the stock L98 heads will are good for 350 fw/hp. (porting would be a good idea), also a good exhaust IE headers, gutted cat (or a better flowing) and as said cam and intake (if you can get a hold of a super ram try that). maybe #24 injectors, and a pcm tune. that should get you fairly close
Old Jan 30, 2008 | 10:17 AM
mrc24x's Avatar
mrc24x
Headers, X-pipe and true duals will get you close to 300hp* for ~ $1200. (My L98 was 250 rwhp / 330 rwtq at that point)
Cam / Heads (aftermarket or CNC your 113's) + intake work will get you over 350hp*. ~ $2500. If you do the labor.
* Not RWHP
Old Jan 30, 2008 | 11:41 AM
L98boy's Avatar
L98boy
* Not RWHP
If installation is done correctly and you use quality parts when replacing the internals of the engine (heads, cam, etc) hurt overall reliability?
Old Jan 30, 2008 | 11:50 AM
JackDidley's Avatar
JackDidley
My L98 had over 85000 miles when I did most of that. No real problems 40000 later. Then it got freshened up and more mods. The key is getting a good chip tune from the start.
Old Jan 30, 2008 | 12:33 PM
vader86's Avatar
vader86
Couple thousand in parts i figure, assuming you can do all the engine work yourself.
Old Jan 30, 2008 | 01:36 PM
KeyWestJack's Avatar
KeyWestJack
What did you have done?
Old Jan 30, 2008 | 03:53 PM
JackDidley's Avatar
JackDidley
Did ZZ4 cam, 180ccheads, Edelbrock/ASM intake.
Old Jan 30, 2008 | 09:41 PM
John A. Marker's Avatar
John A. Marker
You can get about 350 at the crank without too much trouble or machine work.
You don't tell us what year your car is.
My car is a 85 with the bottom end still stock (stock cam and pistons). I am running close to 350 at the crank with the mods listed below and a test pipe instead of the cat. I use this set up for the track.
So if you add AFT 180 heads, 1.6 and 1.5 roller rockers, SuperRam and do some exhaust pipe work it can be done. Add a cam (will have to rework the chip) and you will be over 350 HP.
Old Jan 30, 2008 | 09:47 PM
JackDidley's Avatar
JackDidley
Did anybody notice, colin was here and never came back ??
Old Jan 31, 2008 | 01:16 AM
colinwashere51
Default so
its umm colin-was-here. thanks
Old Jan 31, 2008 | 01:23 AM
colinwashere51
also how much engine speed is a stock L98 bottom end good for
i got an 85 and im pretty ok with a wrench.
im not gonna be a Jerk and say im wonderful.
and for a couple of grand isent it easyer to do an Ltx swap?
Old Jan 31, 2008 | 01:25 AM
Demonic85's Avatar
Demonic85
Here's what i've done to mine and its probably got 300 HP with the stock TPI. You could probably add a Holley Stealth Ram and some good computer tuning to get around your goal. The HSR is like roughly $350.
Heads $1300
Cam Free!
Exhaust $1000
Fuel upgrade $250
BTW: Going from L98 to LTX is a big waste of money. Theres not that much of a difference to justify all that labor. If your gonna swap motors go with a LSX and your already at 350 HP.
Old Jan 31, 2008 | 03:14 AM
racebum's Avatar
racebum
porting the TPI, that's smoothing the TB, doing the plenum, sandblasting the EGR crap out of the runners and matching them. enlarging the base runners and straightening the turns. Using a good long tube, 1.5RR's if you don't change springs, 1.6's if you buy the cheap but quite good LT4 springs. True dual and a 160 thermostat coupled with a TPIS foam or K&N, cut air lid and some of the other free mods i forgot will get a 90-91 car in the low 13s on street tires. My old 91 did a 13.2 with the above mentioned. L98's are affordable to mod up to this point. beyond this you start building bottom ends to take more RPM, buying better heads, getting a SR or MR and doing some tuning. I now have a 1990 car that runs 12.3s and put down 352 or 358 RWHP depending on which dyno day, has a perfectly flat torque curve peaking right about the same number as the HP and would cost stupid amounts of money to re create. Stupid at least from my point of view. You would spend around $8000 to duplicate the setup. These retarded Minirams cost as much as a winter beater car. The receipt i have on the heads is over $2000, there's $3500 on heads and intake. If you have that kind of money to just toss, unload the C4, buy a 2001 or newer c5 and spend less to go faster.
To L98 preformance
Old Jan 31, 2008 | 03:24 AM
mrc24x's Avatar
mrc24x
1) Headers and exhaust will give you more power than an LT1.
2) The other mods will get you close to C5 Z06 power.
All without pulling the motor. (Stock bottom end)
Old Jan 31, 2008 | 03:36 AM
colinwashere51
Default L98
Realy?
How much Rpm can the standard bottom end stand?
just for a safety point of view
i dont want to go putting a high rpm cam set up in it and find out that
the stock wrist pins have a hard time with 6 to 6500 cause you honestly dont need more than that.
Do you have any must have mods you reccomend?
Old Jan 31, 2008 | 03:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
Colin, I hope you know i was yanking our chain a lil
6k is probably safe for the L98s but wouldnt twist it up real high on a normal basis (6500). You could get a better crank kit pretty cheap these days unless you really plan on twisting the motor.
