L98 Piston question
Old Feb 8, 2008 | 08:24 AM
JackDidley's Avatar
JackDidley
Originally Posted by rodj
Enlighten me
3.750 stroker pistons run about .125 different lower CH to accomodate the extra stroke.
Allowing .025 for avg deck height that would put the stock piston .100 out of the bore unless you change rods?
The stock 400 rods are 5.585 if I recall correctly. If you use 350 pistons the stock wrist pin location lets the piston end up where it needs to be. I did it in 1988, before they knew how to make these kits in China.
Old Feb 8, 2008 | 08:33 PM
CFI-EFI's Avatar
CFI-EFI
Enlighten me
Yes, change the rods. You are over thinking the situation, with deck clearances and all, and avoiding the obvious. The stock 350 pistons and the stock 400 pistons have the same compression height. When Chevy added the stroke, besides changing the bore from 4.00 to 4.125", They changed the rod length rather than the compression height of the pistons. All familiar Gen I and Gen II SBCs use a 5.7" rod, except for the 400, which uses a 5.565" rod. [5.7" - 5.565" = 1.35"], or 1/2 of the [3.75" - 3.48" = ] 2.70" difference in the strokes. 350 pistons (+.030"), in a 350 block, plus 400 rods, plus 400 crank (w/mains turned to 2.45") = a 383. All the familiar Gen I and Gen II SBCs have a block, center of mains to top of the block (deck), blueprint dimension of 9.025". Take 1/2 of the 383/400 stroke of 3.75" or 1.875" add the 400 rod length (5.565") and the 350/400 piston compression height of 1.561", and you get, [1.875 + 5.565 + 1.561 = ] 9.001". Mix that combination of parts into a 9.025" block and you'll get deck clearance of .024".
I am CFI-EFI, and I approve of this message.
RACE ON!!!
Old Feb 8, 2008 | 08:45 PM
JackDidley's Avatar
JackDidley
RACE ON!!!
I knew that did not sound right when I posted the 400 rod length. It just would not come to me when I posted. Thanks for posting the correct number, CFI-EFI. I just realised that 1988 was a freakin long time ago. I have a right to forget after 20 years.
Old Feb 8, 2008 | 08:50 PM
rodj's Avatar
rodj
CFI-EFI, I am familiar with the SBC maths.
I was refering to the poster's comment;
"I may have to re-think boring my 85, the cylinders are ok and the pistons looked good maybe I will build a 380 instead of a 383"
which implies he thought he could do a crank swap only,retaining his original rods.
Old Feb 8, 2008 | 09:15 PM
CFI-EFI's Avatar
CFI-EFI
Does it? Rods and rod lengths were never mentioned in this thread prior to my post. You stated, "If you can get the stock pistons to work with 3.75 stroker crank you will be the first" I replied, with "Yes they will. Contrary to what Rodj posted, 'If you can get the stock pistons to work with 3.75 stroker crank you will be the first', you wouldn't be the first.". I had to mention rods because neither before, or after, did you mention you were ***-U-MEing he would have to retain his original rods. You made the statement of "you will be the first". I said he wouldn't, and then you said, "Enlighten me". So I did. Sorry.
RACE ON!!!
Old Feb 8, 2008 | 10:06 PM
rodj's Avatar
rodj
Nothing to be sorry about.
Good to see you are back to your old self
