New scan tool
Old Feb 6, 2008 | 02:39 PM
wheelhorse's Avatar
wheelhorse
Default New scan tool
I bought a AutoXray AX6000 for $295 to do scans on my 1995 with OBDI with the 16 pin DTC. I've read the different info about grounding pin 12 to pin 4 and the Datamaster/laptop route. All this is good stuff. I haven't used this tool yet but I hope that I'll be satisfied with my choice. I know that there is limitations compared with other scan tools. At this time my car has no code issues and is running great. I bought the Factory Service Manuals, so hopefully I'm somewhat prepared to do the diagnosis. Any feedback would be appreciated.
Old Feb 6, 2008 | 06:49 PM
joeld's Avatar
joeld
Go ahead and start using your scanner now, get to know it some. Look at the data on your sensors and record as much as you can while the car is running good with no problems now. This way you will have a good base of info to compare with later.
Joel
Old Feb 6, 2008 | 10:54 PM
wheelhorse's Avatar
wheelhorse
Default Good tip
Establish a baseline and compare with factory specs. It was delivered today and I will do a scan tom arrow. Also came with the software and usb cable to transfer data to pc or laptop.
Old Feb 7, 2008 | 04:55 AM
wilsonbh's Avatar
wilsonbh
I bought a Actron 9190. It too is "supposed" to read OBD 1 & 2 codes but I've yet been unable to get it to successfully read OBD 1 anything. I hope you have better luck than I have. It does read OBD 2 nicely and helped me fix my 1999 NISSAN Maxima. It had a bad ignition coil and the scan tool took me to the exact part. It was greatly satisfying to fix that car so quickly and now the wife thinks I'm a master mechanic. Little does she know that I'm a complete idiot that simply plugged something to the car and followed it's directions.....
Billy
Old Feb 7, 2008 | 11:19 AM
SunCr's Avatar
SunCr
Corvette Enthusiast covers both the Auto X-ray and Actron products this month recommending the Auto X-ray because they couldn't get the Actron to read any OBD1 product - I'd return it.
Old Feb 7, 2008 | 01:45 PM
mseven's Avatar
mseven
I have an auto-x, used it on the vette 3 about years ago and it works well. I like it because it reads all my cars and can read all makes using both obdI and II.
Old Feb 7, 2008 | 02:11 PM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Just picked up an auto x-ray code reader a couple weeks ago. I have tested it on a couple OBD-1 cars and it worked great, even helped a buddy figure out a problem he was having and didn't even know about because his check engine light bulb was burned out
Old Feb 8, 2008 | 02:44 PM
wheelhorse's Avatar
wheelhorse
Default Yes indeed
I used the blue 16 pin connector that came with this scanner and pliged it into the DTC, turned the key to ON,hit scan and it did a successful scan. Then I went to the factory service manual to compare data. It also gave me a code #44 (lean OX2 ). What this tool will not do is clear codes. You have to disconnect the negative battery cable. I now need to do that and then do another scan to make sure it cleared. I also need to get it up to operating temp and do a scan. This is so much fun!! But this scanner reads OBDI with out any problems. It also came with EZ-PC500 software so that I can upload the info from the scanner to my computer.
Old Feb 8, 2008 | 05:35 PM
joeld's Avatar
joeld
Yea, most OBD1 GM's will not clear any codes by the scanner. Have to remove batt cable. You'll get real good at setting radio stations and the clock!
Joel
Old Feb 10, 2008 | 12:35 PM
wheelhorse's Avatar
wheelhorse
Default That's funny
Not to mention disconnecting and reconnecting the negative battery cable. How about a guick disconnect, toggle switch, or something??
Old Feb 12, 2008 | 01:53 PM
Lichen's Avatar
Lichen
My Autoxray5000 will clear codes. When you hit "data", doesn't it give you the option of clearing codes?
Old Feb 12, 2008 | 09:18 PM
wheelhorse's Avatar
wheelhorse
Default Clear codes
Yes, it does give me that option, but when I hit enter to do that function, it was unable to do it. Do I need to try this with the car running? I need to do the "Capture Data" process also and up load the info to my laptop to look at info graficaly. The weather here in Indiana has been to cool to mess with it. The code was in "History" not a "Current" code. Could that be the reason?
Old Feb 13, 2008 | 01:07 PM
Aurora40's Avatar
Aurora40
I can't recall if I could clear codes with my AX-6000 either. It might not have worked. But it's a nice scanner, works on every car I've tried it on so far. It just isn't great for datalogging. But for real-time it's great, and it's smaller and easier than a laptop. So for things like monitoring temps, IAC counts, or other status stuff, it's pretty useful. Datalogging things like knock and such, not quite so much.
Old Mar 25, 2008 | 10:50 AM
larryfs's Avatar
larryfs
the 6000 will data log. I log and download it to my pc.
it will record intervals in 1 sec or 2 secs, or whatever you set it at.
I think it will record 14 intervals, at any interval you like. I find 1 second the most useful.
Old Mar 26, 2008 | 07:56 AM
pcolt94's Avatar
pcolt94
You don’t have to disconnect the battery. You can clear the codes using the on board diagnostics as you would scan for codes. Just like you would connect 4 & 12 on the ALDL connector to look for codes, you go into each module using the .7 submenu section. Like 1.7, 4.7, 9.7. Also you cannot clear codes in module 9 by disconnecting the battery. It has to be done as I said or with a scanner (Tech 1 or such).
I can do this faster than disconnecting the battery and stay cleaner.
Old Mar 26, 2008 | 10:10 AM
dustoff529's Avatar
dustoff529
8th Gear
$295 is a pretty good price for AutoXray 6000 where did you get it?
Old Mar 28, 2008 | 08:12 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Auto X Ray 5000
I bought a brand new Auto X Ray 5000 on ebay for 200$ recently. I like it. I have did 1 and 2 readings with it.
To New scan tool
Old Apr 2, 2008 | 04:29 PM
vette079's Avatar
vette079
tooldiscounter.com?
Old May 2, 2008 | 12:01 PM
Finn Jensen's Avatar
Finn Jensen
Default Actron CP9190
Billy
I have never been able to get this scanner to function on my 92 LT1, and today I finally found out why from Actron. I have used it successfully on other cars, OBD1 and OBD2, but I loose the datastream display on my Corvette after about one second.
Actron tells me that the computer baud-rate on the Chevy high-performance engines of the late 80s and early 90s (Corvettes and Z-28s) is too fast for the scanner to keep pace. So basically the scanner is not usable for OBD1 performance GM applications. There is no current fix from Actron; apparently other scanner manufactures do provide some type of cable adapter to make it function.
Old May 2, 2008 | 03:03 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Originally Posted by vette079
tooldiscounter.com?
Well it is not that web address.
