Converting to 3 wire O2 sensor
Old Feb 6, 2008 | 10:05 PM
Demonic85's Avatar
Demonic85
Default Converting to 3 wire O2 sensor
I need to convert to a later style heated O2 sensor since I put ceramic coated headers on my '85. Does anybody know where I can get both the 3 wire connector and the sensor together? Also how is this compatible with an early ECM?
Old Feb 6, 2008 | 10:14 PM
evmlarry's Avatar
evmlarry
I haven't found one together, but I have seen on ebay tpiparts (I believe) that has the harness and then also you can find pretty good deals on the correct AC Delco sensor there on ebay as well.
As for if it's compatible with the old ECM, basically you have one wire that you run off a 12v source, such as the fuel pump line let's say, then you have one line that goes to ground... finally the last wire goes to the ECM just like the original sensor. Basically you're just adding a heating element to the sensor. The harness I've seen is nice so you don't have to cut and split the o2 sensor wiring if you have to install a new one. The harness is a conveniences piece.
Old Feb 6, 2008 | 10:20 PM
Demonic85's Avatar
Demonic85
Yeah that makes sense. Thanks, now I just need to track down the parts.
Old Feb 6, 2008 | 11:29 PM
Demonic85's Avatar
Demonic85
I found a new GM 3 wire O2 sensor on eBay for $75, is that a good deal or should I stick with the Bosch one ($42) from Autozone?
Old Feb 6, 2008 | 11:39 PM
evmlarry's Avatar
evmlarry
Check your PM here in a few mins...
Old Feb 6, 2008 | 11:42 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I got my sensor from ebay for around $40 and the harness at my local parts place.
I see no reason to pay extra for the GM one.
Old Feb 7, 2008 | 12:33 AM
Demonic85's Avatar
Demonic85
None of the local places keep them in stock, but I got them off ebay for cheap thanks to evmlarry.
Old Feb 7, 2008 | 02:35 AM
BAM92's Avatar
BAM92
Just remember, the black one is the one that goes to the ECM, and ground one of the white ones and the other white one goes to a switchable source, such as a hot wire to a relay for fuel pump or fans.
Old Feb 7, 2008 | 03:28 AM
racebum's Avatar
racebum
One other post on here mentions the Bosch 13190 part number as a go. It is a 3 wire sensor that can be had for $40 or so. My question is where do you guys pull power from? Fuel pump circut or?
Old Feb 7, 2008 | 03:43 AM
Eike's Avatar
Eike
I got a cheap $25 Sensor off ebay and it works great. No need to pay $75 ...
Old Feb 7, 2008 | 05:36 AM
dagrump's Avatar
dagrump
casper electronics
Old Feb 7, 2008 | 07:47 AM
AGENT 86's Avatar
AGENT 86
I took mine from the OD relay. The O2 wire comes out of the harness near it, so it made for a clean looking install.
Old Feb 13, 2008 | 12:56 PM
Demonic85's Avatar
Demonic85
Ok got the parts in, but I have one last question. The last wire goes to a 12v source. What is the best way to wire it in? I dont want to put in the wrong place and put a drain on the battery
Old Feb 13, 2008 | 12:59 PM
vader86's Avatar
vader86
You could wire it to the wiper motor for example. On my car I might wire it to the MAF relay or cooling fan relay.
Old Feb 13, 2008 | 01:39 PM
Demonic85's Avatar
Demonic85
Dont have a MAF relay but the cooling fan relay is within reach, thanks
Old Feb 13, 2008 | 03:55 PM
racebum's Avatar
racebum
Anyone ever wonder why there are 3 wires? i mean the 02 itself would be a ground since its screwed into metal tubing which goes straight to the block. Anyone know the reasons on this one? just a curiousity thing.
Old Feb 13, 2008 | 04:34 PM
redrose's Avatar
redrose
fwiw, i prefer the 4-wire heated o2 sensor as used 94-04 vette (upstream sensor) as it has a dedicated ground wire for the sensor element...the matching connector can be found in the j-y on zillions of 3.1 GM v-6's, such as 94-96 corsica, etc and is up high just behind the alternator, easily "canned", usually not too dirty...if really on a tight budget ( a new sensor is abt $50 at napa) the 4-wire o2 sensor from those (same as vette 94-04) will often unscrew "cold" (you will need a "slotted" 7/8'' o2 sensor socket to get past the exh manifold heat shields readily),look on top center of rear exhuast manifold, also accessible without crawling under the car....tan wire (term A on connector) and purple (term B) connect to ecm (wire colors match typically) input and sensor "low"(ground), black wire (term C) to engine ground, pink wire (term D) to 12v ''hot in run only"
To Converting to 3 wire O2 sensor
Old Feb 13, 2008 | 05:16 PM
Demonic85's Avatar
Demonic85
I dont believe the wiring circuit itself is grounded though. Even though it might be fine, its probably safer to have that ground.
As for the 4 wire sensor, I dont see what the difference is, I mean they do the same thing as a 3 wire (heated). I have to crawl underneath the car anyway since I have headers the sensor is at the end of the collector.
Old Feb 13, 2008 | 05:34 PM
vader86's Avatar
vader86
One provides a constant heat source to the sensor element.
Old Feb 13, 2008 | 10:28 PM
redrose's Avatar
redrose
corrosion (rust) at the theaded sensor/manifold interface may degrade the signal to the ecm with sensors not equipped with the "4-wire" wiring, resulting in poor engine performance and increased emissions...under "ideal" conditions both perform as reqd.
reference previously made to "crawling under" was only directed to acquiring the 4-wire connector and/or sensor from a "donor" vehicle, sorry if that was not clear.
