Trans question
Old Feb 11, 2008 | 06:40 PM
Turbo Kid's Avatar
Turbo Kid
Default Trans question
Hi please tell me what year the 4+3 trans was replaced with the real 6 speed in the c4 vettes.Thanks
Old Feb 11, 2008 | 06:53 PM
CFI-EFI's Avatar
CFI-EFI
The 4+3 was used 1984 through 1988. The 6 speed started in 1989 and continued through 1996, the end of C4 production.
RACE ON!!!
Old Feb 11, 2008 | 11:37 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Two models were available. "Black tag" & "blue tag". The black tags were in the 89-93s, blue in 94-96. (If the years are wrong, someone please correct it.) The black are stronger (rated at 450 lbs. torque) while the blue are quieter and rated at 400 lbs.
Check the C4 Technical notes at the top of this section. Lots of info there.
Old Feb 12, 2008 | 10:58 PM
El T1's Avatar
El T1
RACE ON!!!
I concur. I had an '89 several years back, and it had the 6-spd.
FYI: nice tranny, but mine (and others of that ilk I've heard of) had third-gear synchros that were less than long-term prospects.
Old Feb 12, 2008 | 11:51 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Can the 4+3 be replaced with the 6 Speed tranny? Is there a kit?
Old Feb 16, 2008 | 07:48 PM
pappyfreebird's Avatar
pappyfreebird
i be innerested in that last question too....and can a standard tranny shop do it??? mines fine i think...but have seen alot of replacin goin on
Old Feb 16, 2008 | 08:31 PM
CFI-EFI's Avatar
CFI-EFI
Anything can be swapped into anything, given enough time, money, and effort. I am not aware of any kit, but I know it has been done. Check the search function, because I believe there has been quite a bit written on the subject.
RACE ON!!!
Old Feb 16, 2008 | 08:48 PM
rodj's Avatar
rodj
RACE ON!!!
You need all the parts from a ZF6 car including the tunnel section to graft in where the shifter mounts.
C beam back the same but need ZF6 yoke.
Start looking at junkyards.
To Trans question
