LTx rotating assembly questions
Old Feb 12, 2008 | 07:45 PM
ScaryFast's Avatar
ScaryFast
Originally Posted by Tom Piper
But, if you are talking over 420 flywheel hp or reving higher than the LT4, I would start thinking after-market dampers.
Yeah, forgot about the damper. I put an ATI piece on mine. Thank goodness Tom and Will showed up or I would have forgotten to mention that key part...
It has the added advantage of making the Optispark removeable without removing it first. A fact I've taken advantage of already.
Old Feb 12, 2008 | 08:28 PM
Mojave's Avatar
Mojave
Which ATI damper are you running?
I see 1 steel and 3 aluminum. I would ASSume I want it to be under-driven, so the 917275 and the 917273 look good, but I'm not sure what the difference is between them.
Edit: Looks like one includes hardware and one doesn't.
Old Feb 13, 2008 | 11:17 AM
ScaryFast's Avatar
ScaryFast
I'll have to check. It's aluminum. If I remember correctly there's one for the F body and one for us. I should have the PN at home if you want it.
Old Feb 13, 2008 | 11:44 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Brad,
the #275 is the 6 7/8' underdrive with a steel hub. It comes with fasteners and also a spacer for 94/95 to compensate for the reluctor ring you have on the 96 so spacer is not required. I have owned two of these dampers over the years and currently run one on the 95 with good results. Almost went with the aluminum hub option but figured it would be overkill for the street unless you race it full time and want the lightest possible. The only difference I saw in the newest damper versus the old one was the 3 bolts that go in the front face for removal were different. They went with a clutch head type bolt rather than a oval allen head bolt head. This reduced my clearance between the face of the damper bolt head and the steering rack housing to about an 1/8 inch. I swapped out the bolts for new oval allen head type to get back about 5/16" clearance. May not be your problem but thought I would mention it. Good luck.
Rick Geer
Old Feb 13, 2008 | 12:09 PM
Mojave's Avatar
Mojave
What is the part number for the all aluminum unit?
Old Feb 13, 2008 | 12:16 PM
PDQUIK95's Avatar
PDQUIK95
Brad,
All aluminum hub and shell is 917273.
steel hub /aluminum shell is 917275.
If you buy pieces seperately, then the shell part no# is same for both 91707144.
the steel hub only is 916096A.
the aluminum hub only is 916094.
I took this right off there web site.
RG
I have installed 4 or 5 of these dampers for myself and other people before but only one aluminum hub type. The interference for aluminum type is about .002" or more vice about .001" for steel if my memory serves me correctly. I used a hot plate to heat the alum. hub a couple hundred degrees to help install it on the crank snout. Seemed to work pretty good. Just had to install fairly quickly while hub was still hot.
Old Feb 13, 2008 | 07:30 PM
Mojave's Avatar
Mojave
So, if I'm doing rods and pistons, I might as well make it a 383, right?
I was looking at some inexpensive stroker cranks.
http://store.summitracing.com/partde...E&autoview=sku
http://store.summitracing.com/partde...2&autoview=sku
http://store.summitracing.com/partde...0&autoview=sku
Are any of those decent? Or, what is recommended? I really don't need a forged crank and definitely can't afford one, so I would have to stick to the cast stuff. I know the stock LT1 is internal balance at the front and external at the rear, but I would ASSume I want to internally balance it and get my flywheel neutral balanced.
How much clearance work is needed on the block with 6.0" rods?
Old Feb 13, 2008 | 07:43 PM
95wht6spd's Avatar
95wht6spd
From what I have read, the weak link is the rod bolts, so I would at least replace those w ARP bolts.
Old Feb 13, 2008 | 07:59 PM
rklessdriver's Avatar
rklessdriver
I sent you a link to a SCAT 9000 series cast cranks. It is internal balance. As far as budget priced stuff they are the best going.
As for the balance, Yes IMO you would want to have internal balance. I know you said you had an Alum FW. If its a Fidanza Alum FW the weight just unbolts, easy to make it neutral. I have used that particular SCAT crank with both neutral and the stock weighted FW's before and they balance out fine either way - as long as the bob weight is under 1750. Over that you are going to need a few slugs of mallory depending.
Clearancing on the block is totally dependant on what rods you are using. If you are using those C&A's we talked about, I honestly couldn't tell you as I've never used that particular rod before. It's usually not a whole lot of work as long as you have a good die grinder and carbide bur.
Will
Old Feb 13, 2008 | 08:17 PM
bobmic93's Avatar
bobmic93
Mojave, I here you when you say your on a budget but you are already in deep with this motor and will kick yourself later for not doing the forged 383. If you have no kids that are depending on you for food and shelter, I say do it! Pull out the credit card. Do what it takes. A 383 LT4 with a LE top end. Your gonna need new rear tires every summer! 425 rwhp 415 rwtq
Old Feb 14, 2008 | 12:14 AM
Mojave's Avatar
Mojave
Well, I emailed Lloyd, and he is going to spec another cam to go with a 383. Unless I'm way off base, the Scat 9000 cast should be more than enough crank for me, but the rods and pistons will be forged. My LT4 heads are already done (bigger valves, porting, also ported intake).
I'd really like to see 425 RWHP, then if I could get a few more pounds off of my car, it would be bye bye C6 Z06!
Old Feb 15, 2008 | 12:17 AM
Mojave's Avatar
Mojave
So, now that I'm going to be making more power, what to do for a clutch. 1 week before it exploded, I put in a new stock Valeo clutch and Fidanza. I definitely want to keep the Fidanza, but will a stock clutch even stand a chance with this kind of power?
Most usage will be RR/Auto-x, but I'm sure I'll take it to the strip at least once to make all the local drag racers shutup.
Can I expect some decent life, or am I going to be pulling the stocker back out in a month? I'm really tired of taking the trans in and out...
Old Feb 16, 2008 | 10:31 AM
  #33
ScaryFast's Avatar
ScaryFast
I used a Carolina Clutch stage 3 with a Fidanza flywheel. Works great, slightly higher pedal effort no slippage after two seasons.
BTW, don't get your hopes too high, 425 rwhp is pretty optimistic. Shoot for around 400 so you can keep it robust.
I can send you video of my car pulling on a C5Z down the back straight if you don't think that's enough hp...
Of course later in the same video is an EVO pulling away from me like I am standing still
Old Feb 16, 2008 | 11:37 AM
  #34
95wht6spd's Avatar
95wht6spd
If you are doing an LE3 heads/cam on a LT4 383 you should put down 425-440rwhp with all extra mods.
Old Feb 16, 2008 | 04:26 PM
  #35
Mojave's Avatar
Mojave
I don't have exactly an LE3 setup, but the specs are close. Maybe my goals are a bit excessive, but 420-425 would be nice. I am stepping up to 1 3/4" headers, ported intake, bigger throttle body, and 37 lb injectors. It will be dyno tuned by someone, but I'm not sure who (and I may tweak on the tune a bit myself...)
ARP main bolts or convert to main studs?
Old Feb 16, 2008 | 05:09 PM
  #36
prism_kiter's Avatar
prism_kiter
hi mojave,
i would go arp head studs and arp main cap crank studs as i have done.
you can never be surer enough i say!!
cheers
Old Feb 16, 2008 | 08:05 PM
  #37
kowalski340's Avatar
kowalski340
Hey mojave I look at your site at least once a week to see if there are any new entries!! When is there going to be an update? hopefully with pictures!!!!
Old Feb 16, 2008 | 08:13 PM
  #38
Mojave's Avatar
Mojave
There will be pics soon. Hard to take pics of parts until you get them. But I did get my rods today: 6.0" Childs and Alberts. They are pretty....
