Camshaft
Old Feb 16, 2008 | 08:49 AM
Pete K's Avatar
Pete K
Originally Posted by bobmic93
Why not run it on a 110LSA?
Compromise.
I never aim to build the best, fastest stuff. Usually I am factoring in fuel milage, idle quality, vacuum, power and torque.
My motors never set records, or raise the standards, but they usually run better than most. I use 112 lobe centerlines in all my stuff. Stuck in my ways I guess.
Old Feb 16, 2008 | 10:16 AM
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by jsup
Pete was smart and bought a set of AFR's. You would of as well, if you knew the price we paid.
Old Feb 16, 2008 | 10:17 AM
88BlackZ-51
Originally Posted by Pete K
Compromise.
Your so modest. This motor with a miniram on it, and that cam, and the AFR's will kick ***!!! What internals, and compression ratio are you thinking?
Old Feb 16, 2008 | 10:25 AM
Pete K's Avatar
Pete K
Budget rotating assembly and it should yield approx 10.3 to 1 compression. With the price of fuel, I am staying under 11 to 1 on my builds, preferably under 10.5 to 1.
In my eyes, the 1 point compression gain simply is not risk the power increase.
I would hope the combo would run close to 11.50 @118
I will take what it gives though.
The race wheels and tires I bought from SeeeYaaa will hopefully make my current package consistant 11.80 @116.
My 9.5 inch converter that is sitting on the shelf may yield a tenth or 2 also.
On paper the 406 may even work better than I expect, but I do not ever get my hopes up.
Old Feb 16, 2008 | 10:29 AM
88BlackZ-51
Sounds great. We are going to both have some stout motors this year. If the AFR's live up to the hype, you might even hit 120 mph.
