Camshaft
Old Feb 15, 2008 | 09:32 PM
Pete K's Avatar
Pete K
Default Camshaft
Ordered my new custom grind cam today
pr0zac's Avatar
pr0zac
can you order me one too??
Old Feb 15, 2008 | 09:35 PM
Pete K's Avatar
Pete K
All it takes is some green
Old Feb 15, 2008 | 09:36 PM
pr0zac's Avatar
pr0zac
i got a whole lawn full of green.check the avitar.lol about what are the specs of this new toy??
88BlackZ-51's Avatar
88BlackZ-51
Come' on. What are the specs? Is this for the 406 or the 421?
Old Feb 15, 2008 | 09:39 PM
Pete K's Avatar
Pete K
It is for the 406.
The cam is a pup.
230 @ .050 on the intake with a .375 lobe lift
236 @.050 on the exaust with a .380 lobe lift
112 lobe seperation
Ground on a billet core, straight up, with a pressed on iron gear.
It is on a 1.050 base circle
It is the most aggressive ramps available in that lobe.
Old Feb 15, 2008 | 09:55 PM
pr0zac's Avatar
pr0zac
that is about what i have.. my cam is not custom by any means.. but that should pull like a mother in a well setup motor..
Old Feb 15, 2008 | 09:57 PM
88BlackZ-51
Originally Posted by Pete K
It is for the 406.
The cam is a pup.
112 lobe seperation
Sounds great. Intake will be the miniram?
Old Feb 15, 2008 | 09:58 PM
Pete K's Avatar
Pete K
Or the single plane
Pretty pleased with the lobe profiles. Huge .200 numbers
Old Feb 15, 2008 | 10:01 PM
88BlackZ-51
Or the single plane
And the 195cc AFR's? Looks like you are going to be using new parts now!!
Old Feb 15, 2008 | 10:02 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Old Feb 15, 2008 | 10:05 PM
Pete K's Avatar
Pete K
Should make big power.
The old 406 made 480 hp with a much smaller cam, and a whole lot less cylinder head.
Old Feb 15, 2008 | 10:36 PM
prism_kiter's Avatar
prism_kiter
hi pete,
yeah nice cam you picked.
i also just recieved my new comp cam hydraulic roler cam to go in a 388c.i all forged ,light weigh component engine!
this is a custom grind also...
it is a 236/242 @ .50" duration,
with 286/292 advanced duration,
.580/.585 " lift @ 1.6 ratio
111 lobe seperation,
4-7 fire order cylinder swap,
small base circle with Billet core.
should kane bloody hard as well hopefully!
cheers
Old Feb 16, 2008 | 01:13 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
It is for the 406.
The cam is a pup.
112 lobe seperation
Same cam shaft I have but you have more lift, and I added +2 on the LSA
Old Feb 16, 2008 | 01:32 AM
cv67's Avatar
cv67
St. Jude Donor '05
Or the single plane
Old Feb 16, 2008 | 01:51 AM
RRT vette's Avatar
RRT vette
Sounds like it's going to be a monster.
Old Feb 16, 2008 | 02:37 AM
Curveit's Avatar
Curveit
Strap down tight and hang on...
To Camshaft
Old Feb 16, 2008 | 04:41 AM
bobmic93's Avatar
bobmic93
Why not run it on a 110LSA?
Old Feb 16, 2008 | 08:21 AM
Z51L9889's Avatar
Z51L9889
Very nice, Pete!
That cam should be a sweetheart in a 406.
Old Feb 16, 2008 | 08:46 AM
L98boy's Avatar
L98boy
