coil difference
Old Feb 16, 2008 | 01:21 PM
lil_red_devil's Avatar
lil_red_devil
Default coil difference
Hi guys,
I have a friend that has an 86. Can you tell me what the difference between these 2 coils are? One has red white and black wires and one has a red yellow and black.
Are they interchangable of are they different coils?
Thanks for your help
Old Feb 16, 2008 | 02:24 PM
CFI-EFI's Avatar
CFI-EFI
It is a matter of polarity. If you were stranded on the side of the road, the incorrect coil will get you going. You might never notice the difference, but it won't have the current capacity of the correct coil. The color of the coil leads should match the color of the module leads.
RACE ON!!!
Old Feb 16, 2008 | 03:05 PM
lil_red_devil
does the white wire on one coil and the yellow on the other indicate that they are of different capacity?
Old Feb 16, 2008 | 05:28 PM
WW7's Avatar
WW7
I had the same question so I called Accel about which one to use. The tech guy told me the same as CFI-EFI stated, they have different polarity, but he did tell me that they have done tests and either one will work. I have a 89 so I did go ahead and get the red/white wired coil which is the correct one for my car. You can't go by what the different parts sites say because they don't agree with each other, thats why I called Accel. WW
Old Feb 16, 2008 | 06:00 PM
lil_red_devil
thanks for your help guys
never worked on a c4 before (other than bypassing a fan switch on a road trip to get me outta the sh...)
will pass on the info
Old Feb 16, 2008 | 08:41 PM
CFI-EFI's Avatar
CFI-EFI
It isn't a matter of capacity. Either coil will have a reduced output in the wrong application. Reversed polarity of ignition coils and the problems it can cause are as old as the points and a condenser (Kettering ignition).
RACE ON!!!
Old Feb 17, 2008 | 12:45 AM
Wingralf's Avatar
Wingralf
the coils are matched to the pick-up coil's polarity if that helps and a wrong one does cause problems as cfi-efi stated. pick up coil in my 85 is a green/white wires and its coil is a red/white. red/yellows more common to older hei and/or other gm cars/trucks.
To coil difference
