Is it running ok?
I bought a 90 vert that was in a accident just over a year ago and Its going to be ready for the road this spring. It has never seen the road besides moving it around. So my problem is that I took it in for an alignment and finally stepped on it. It seems sluggish and has a rough idle, but start instantly. How do I know if all the injectors are working? or is there another issue. And by the way the wires, plugs....etc.. were all done.
After pic, and the car is really dirty.
I'd do that before just thinking fuel injectors are bad.
Also, get an FSM and go through some of the troubleshooting in there. You might just find your answer with a little reading of it.
FSM.....factory service manual
Fuel filter passenger side tucked in near the rear of front wheel by rocker panel. The fuel filter will not be easy to remove...I have a 90 Vert also and had to drop the cross frame(only verts have them for body rigidity). I see you have a 91+ rear bumper..
The injectors..if original are" Multecs"(1989-19991 crap). Check the resistance on each one with an ohm meter..16.5 +/- .5 is the spec. If they are looking like 15 ohms and less are all over the place..they are on their way out..DO NOT REPLACE with Multecs. I changed mine last summer with only 17,000kms(10,500 miles) on the Vette...went with Accel silver tops.
I wish that my car was that "dirty"
Good advice above, you should be fine
