Replacing front Ball joints
Old Feb 18, 2008 | 08:38 PM
StealthLT4's Avatar
StealthLT4
Default Replacing front Ball joints
How big of a job is it? After lowering my '96, I took it to the alignment shop, and they showed me that both the upper and lower ball joints on both sides of the car are shot (I knew this, but hoped it wasnt as bad as it is), and need to be replaced before it can hold an alignment.
Of course, they priced me like $600 just for one side, but I looked up on Mid America and found a rebuild kit including all 4 ball joints and the inner tie rod ends (I need them as well) for $250. How big of a job is it? I know how to get to the ball joints, but what about getting the old joints out of there and new ones in? I have the FSM, but not with me. Thanks!
Old Feb 18, 2008 | 08:52 PM
86GoldProject's Avatar
86GoldProject
Get a ball joint press. It presses the old ones out and the new ones in. Normally you can get ball joints out with one swift blow with a hammer though. What brand parts are in the kit? Sounds like a good price if the parts are decent quality.
Old Feb 18, 2008 | 08:56 PM
86GoldProject
here is a extremely low priced kit from harbor freight http://www.harborfreight.com/cpi/cta...emnumber=38335
Old Feb 18, 2008 | 09:31 PM
StealthLT4's Avatar
StealthLT4
Thanks for the Harbor Freight link. I'll take a look around and see what I can afford
Here is the kit I am talking about: http://www.mamotorworks.com/corvette-3-153-1122.html
It says they "exceed OEM specs", whatever that means. I am confused though; are the A-arm bushings included? It sounds like they aren't, but if they aren't then the individual components are cheaper than $250 ($230), those being the set of 4 ball joints and 2 inner tie rod ends.
Old Feb 18, 2008 | 11:43 PM
quickcat's Avatar
quickcat
I have photo's from when I did my lowers and can post them in a how to format like I did for the rear axle if it would help out. (see http://forums.corvetteforum.com/show....php?t=1846086) They include using the ball joint tool. Just about the only thing the uppers would add to the job is the hassle of drilling out the rivets (if so equipped). Plan on a full day to finish the job. It will probably go faster if everything goes your way.
I would also recommend renting the tool from your local discount auto parts house. It will save you some cash unless you desire to have the tool. You won't use it much but sometimes it is nice to have these things.
Matt
Old Feb 19, 2008 | 02:14 AM
BAM92's Avatar
BAM92
Upper is easy as all you do is drill out original pop rivets and replace with provided nuts and bolts in kits. Bottom is tough. I took mine to a shop and had them press out and reinstall.
Old Feb 19, 2008 | 10:42 AM
StealthLT4's Avatar
StealthLT4
Did you just take them the A-arm and have them do it? Or was it still on-car?
QUESTION: How do you get the rear-ward bolt out of the lower control arm? I tried this weekend when I was wiggling my spring out, but the bolt hits the frame before it's completely out, and I can't see any way of getting it out save cutting it in half and buying another one, then inserting that one in from the opposite direction (bolt will go in from the inside of the arm, not outside) when it comes time to reinstall. ???
Old Feb 19, 2008 | 07:32 PM
BAM92's Avatar
BAM92
I took them the lower a arm. The bracket that it hits can be unbolted but you have to support the engine on that side. Or I guess you could drill a hole in it and pull the bolt through.
Old Feb 19, 2008 | 08:59 PM
86GoldProject
don't be intimidated, it really isn't a hard job at all...quite easy to do on the car with some basic mechanical ability and a decent ball joint press.
Old Feb 19, 2008 | 10:13 PM
Vettehappy's Avatar
Vettehappy
Went through this on my 96 a few months back, that bracket can be removed without supporting the engine. I didn't believe it at first but several people on the forum advised me, and sure enough they were correct. It does not support the engine mount.
And like 86Gold says don't be intimidated it is not that bad of a job, although I did cheat and remove the arm and have a machine shop repress the new ball joints. Good luck
Old Feb 19, 2008 | 10:22 PM
StealthLT4's Avatar
StealthLT4
Thanks guys. I feel a bit better now. I know how to get to the joints, and how to take the control arms off; it sounds like the ball joints themselves won't be much of a problem with the right tools, which I will work on borrowing, or possibly just taking them somewhere.
What kind of money were you charged for replacing the joints? Also, did they grease them and everything, so they were ready to be bolted back up?
Old Feb 20, 2008 | 06:16 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
I would just add one thing to all the great info that's been offered by all the other guys here......be very wary of ball joints that seem to be inexpensive.
I'm kind of old so I tend to stick with the stuff that has worked for me in the past......Moog only, the ones we used to call "gushers", the stud cup has relief holes for the new grease to force the old grease out when you do your lube work. These are waaaay expensive, but peace of mind sometimes isn't cheap. JMHO.:o
Tom
Old Feb 20, 2008 | 07:43 AM
Tom Piper's Avatar
Tom Piper
Tom
I think I am correct when I say this affects the ball joints for C4s -- the recall says "Upper Ball Joint", but I think it is a C4 "lower."
If you have Moogs, I would check the date code against the recall.
Moog recall:
http://www.allworldauto.com/recalls/...all_44145.html
Tom Piper
Old Feb 20, 2008 | 12:13 PM
tomtom72's Avatar
tomtom72
Moog recall:
Tom Piper
Okay you got me there Tom!:o
made between '89 & '00, and 415 units?????? that can't be four hundred and fifteen....I'm gonna go look up the p/n because as you pointed out a doubt about the p/n's.
I still have the OEM joints in my 90.....they don't fail any of the traditional tests and they haven't failed the FSM test yet. I still stand by what I said about being sure about the quality of the parts ya buy though.....I'm kind of from the "there is no free lunch" school of thought.
Tom
Old Feb 21, 2008 | 11:08 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Do you have a picture or name of this bracket. I am getting ready to do the bushings/ball joints and would like a heads up.
Old Feb 21, 2008 | 11:57 AM
StealthLT4's Avatar
StealthLT4
You'll know it when you see it, lol. The rear-ward bolt on the lower control arm has about 2" between the A-arm mount and some other surface that it hits before it can be removed. I didn't see any way of removing the bracket, but apparently it can be.
Old Feb 21, 2008 | 12:23 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
In my experience nothing is too difficult with a service manual and this place
To Replacing front Ball joints
Old Feb 21, 2008 | 10:57 PM
steve40th's Avatar
steve40th
I was just wondering if you or anyone had pictures or advice on how to get this out. The FSM is okay, but it is also designed for a mechanic faliliar with the automobile, as I have used the FSM for years.
Old Feb 22, 2008 | 07:45 PM
Vettehappy's Avatar
Vettehappy
I sorry for not getting back to you sooner, from what I remember there was four bolts for each bracket. I will dig out the FSM and see if I can scan a picture for you a little later.
Old Feb 22, 2008 | 08:05 PM
steve40th's Avatar
steve40th
Thanks, is that plate spring protector plate?
