Accell Injectors suck
Old Feb 23, 2008 | 11:28 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Default Accell Injectors suck
Hi All, anyone got a bead on a set of flow matched injectors for an 87? My Accell 24's are flooding my motor.
Old Feb 25, 2008 | 09:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is an Ebay seller that has serviced injectors for a good price. Somewhere around $140 for a set. Just a thought
Old Feb 25, 2008 | 09:45 AM
AGENT 86's Avatar
AGENT 86
http://cgi.ebay.ca/FIC-FUEL-INJECTOR...QQcmdZViewItem
Old Feb 25, 2008 | 11:36 AM
1955VETTE2007's Avatar
1955VETTE2007
Cruising
Default injectors
i used these guys. they really fixed me up i have a 87 eng in a 55 body with all stock 87 controls. the 24's were too big. i got a flow matched set of 22lb. for like 149.00 runs great. see it at barrett jackson in florida march.
heres the link
www.fuelinjectorconnection.com
Old Feb 25, 2008 | 01:25 PM
RRT vette's Avatar
RRT vette
If you kept your old injectors, you can send them out for servicing. About $100 to service all 8 and about $10 to service the cold start valve if you still have it.
Old Feb 25, 2008 | 07:58 PM
1955VETTE2007
Cruising
Default only one problem with servicing
the best thing you can do is get rid of those old rochester injectors. wasting a hundred plus shipping and the car down makes no sence when you can get reconditioned bosch 22lb injectors that make the car run great. everyone will tell you that multec injectors are a time bomb. clean or not they will self destruct.
Old Feb 26, 2008 | 08:53 AM
87FIREREDRAGTOP
Looks like a good deal to me, I picked up a set of the E-bay injectors. Thanks guys.
Old Feb 27, 2008 | 09:27 AM
Sam Lam's Avatar
Sam Lam
I have seen many posts where people recommend placing 24 pounders in a 22 pound engine. Sometimes it works.....and sometimes it does not. This post is a testament of the "NOT"! I guess some think that more fuel is better......like the old days
Old Feb 28, 2008 | 08:58 AM
87FIREREDRAGTOP
If the Accel 24's actualy flowed at 24 they would be fine, however, the Accel's are flowing closer to 34, thats where the problem is. I have adjusted my computer to compensate for this, however, they are also not flowing evenly between the cylnders. I have some rich and some lean. I hear they have switched manufacturers since I purchased mine. I just feel sorry for those who believe Summit Racing when they say no computer modifications are needed. Those people are going to have an extremly short engine life.
Old Feb 28, 2008 | 09:20 AM
Sam Lam's Avatar
Sam Lam
Just curious, how were you able to determine the flow rate was about 34 lb/hr? WOW.....that is WAY out of their published spec
Old Feb 29, 2008 | 09:58 AM
87FIREREDRAGTOP
By adjusting my computer to bring the BLM's into specs. Your right, 34 is way out there.
To Accell Injectors suck
