Water Pump Questions?
Old Dec 5, 2001 | 12:21 PM
CG77VETTE's Avatar
CG77VETTE
Default Water Pump Questions?
1.) What are some of the symptoms of a bad water pump?
2.) How difficult is it to replace?
3.) What is a fair price for replacing it (parts & labor)?
Thanks in advance for any help.
Old Dec 5, 2001 | 12:54 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Water Pump Questions? (CG77VETTE)
1) Leaking. Loose shaft. If you can't see it leaking, remove the belt and see if there is "play" in the shaft. If not, it's probably OK. A water pump doesn't get "weak" with age. If the bearings and seals are good, and it's turning, it's pumping.
2) It is a fair amount of work. Before you finish, you'll swear that Chevy sent the water pump down the assembly line and built the car around it. It is NOT difficult, just a little involved.
3) My advice is to make several calls in your local area. Shooting from the hip, I'd guess $250.00 to $300.00. It's been a hundred years since I had anyone do it for me. Buy a pump for $60.00 to $100.00 and do it yourself.
Old Dec 5, 2001 | 12:57 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Water Pump Questions? (CFI-EFI)
My local garage charged me $280 to do mine on my 86... took them right around 4 hours.
Would of done it myself had I the place to do it..
Old Dec 5, 2001 | 01:13 PM
snydcat's Avatar
snydcat
Default Re: Water Pump Questions? (Springer's 95)
Wow, I guess I got lucky my mechanic charged me $120( I supplied the pump ) and It took him a little over 2 hours.
Rich
To Water Pump Questions?
