Warm start issues
Old Feb 28, 2008 | 12:49 PM
86C4VETTE's Avatar
86C4VETTE
Default Warm start issues
When I first start my car up after sitting for awhile it cranks over nice and quick. It is another story when the cars hot, the starter acts like it can barely turn the engine and takes a few tries to get it to crank over. It seems like electrical / starter issue. Any suggestions?
Old Feb 28, 2008 | 09:59 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Heat can eventually kill your starter, sounds like your almost there.
Old Feb 28, 2008 | 10:35 PM
sexasomniac's Avatar
sexasomniac
Yeah, tell me how fun it is when the solenoid sticks and drains your battery within a minute so you get to replace it that weekend.
Old Mar 2, 2008 | 04:17 AM
RRT vette's Avatar
RRT vette
Old Mar 2, 2008 | 08:14 AM
Muffin's Avatar
Muffin
Spring for a mini starter and be done with it.
Old Mar 2, 2008 | 09:31 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
2015 C3 of Year Finalist
Alot of these hot start problems that are diagnosed as heat soak on the starters are actually a weak battery. Don't dismiss that as a possibility. Also check your grounds/connections at the starter and battery.
Old Mar 3, 2008 | 09:20 AM
86C4VETTE's Avatar
86C4VETTE
Thanks for the input, I will be checking things out when I have some down time!
Old Mar 5, 2008 | 11:29 PM
AdoptAVette's Avatar
AdoptAVette
My '91 would do the same thing, except sometimes on occasion it wouldn't want to turn over even when cold.
Everyone told me it was the starter but it ended up being the infamous head gasket leak at cylinder 7 (driver side firewall). A minor leak developed putting enough coolant into #7 cylinder to cause hydrolock. Depending on the compression stroke at startup, it was too much compression for the starter to turn the engine over.
It might not be a head gasket. But its very easy to pull spark plugs and see if any coolant comes out or if any of the plugs are super clean.
To Warm start issues
