How much more power???
Old Mar 2, 2008 | 12:04 AM
red L98's Avatar
red L98
Default How much more power???
Sup guys,
Trying to get somewhat of an idea of the HP gains we should expect from this motor we built. it has my old short block which is a 434 CI sbc and one of my old cams. Lot of the part are off my old motor.
Specs:
434 CI
AFR 220
Super Vic intake “fully ported"
12.1 compressions
264-272@50 650-688 lift 110 lobe 4/7 swap
jessel belt drive
The head flow numbers are:
IN/Ex
.100 66-58
.200 147-112
.300 216-152
.400 262-190
.500 295-222
.600 298-248
.700 304-260
Now the motor has been 10.8s before we changed few things,
Things we changed:
Old cam: 252-252@50 630-630 lift 110 lobe
Old compression : 10.8
Belt drive
fully ported intake
more porting to the head mostly EX side with a total gain of 25 CFM EX
15 CFM intake.
No PS pump
and thats about it ,
thanks
Old Mar 2, 2008 | 09:01 AM
bjankuski's Avatar
bjankuski
My best estimate is the new engine should make 600HP to 625 HP, the old engine 550 HP to 575 HP.
Old Mar 2, 2008 | 12:20 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
the head looks like they quit making good numbers by 500 lift they sort of flatten out by then the cam looks preety big i would have kept the same cam in first run it then change it to see if there is any improvement it could stay the same to 1-2 tenths max i think you did enough positives to out weigh the negatives but not by much
To How much more power???
