Hi guys couple questions, is thier any Aluminum performance cylinders that have a 64cc combustion chamber or less, angle plugs and around 180cc intake ports that do not have heat risers and will fit an 1988 L-98?
-I know GM fast burns fit this profile as do the Lingenfelter L-98 ported heads
haven't seen any AFR, Edelbrock or Trick flow heads that fit this profile.
-do the patriot 180 heads have heat risers, they didn't say on thier sight?
-is it a problem if I put heads that have heat risers on my motor when my 113's didn't originally come with them???
I thought you were going to re-work your stock heads yourself.
I did mine, but I concentrated more on efficiency than port volume. It was a great beer drinking project.
I appreciate all the help guys, I might still port my stock heads, I was just mulling through all the options and wasn't sure about the heat riser issue but thanks to you guys, I now know its a non-issue.
