Have to replace my outer door handle. Any pointers????
Old Mar 7, 2008 | 08:25 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Have to replace my outer door handle. Any pointers????
The door handle on the 95 is broken so I have to pull it, and switch the lock to the new handle. The FSM makes it look like a major PITA. Is there anything I should look out for????? I'm really not looking foward to it
Old Mar 7, 2008 | 09:06 AM
69mako's Avatar
69mako
Its not that bad of a job...just take your time and follow the FSM...maybe about an hour to and hour and a half...have a few beers while your doing it to relax.
Old Mar 7, 2008 | 10:23 AM
LouisvilleLT4's Avatar
LouisvilleLT4
If you have your FSM, you have a lot more knowledge to draw from than I did when I took this job on. I've done this job so many times that at this point I take it for granted, and no longer have any idea which steps were not obvious the first time around, but I'll try to guess.
Having a very small 1/4 ratchet goes a long way.
Don't try to do it without removing the aluminum sheet; removing the sheet is easy. Be sure not to accidentally loosen bolts that are meant for window stops or you might throw off your window alignment; there's only one larger bolt on the alumimum sheet that needs to be loosened, none of the other larger bolts in the door need to be touched.
Be sure you learn how the little clips work where the lock rods attach. Once they're loose, you may need to use pliers to force the rod out of its hole. Once you master those little devices, getting the rods out of the door and out of the way is easy.
Old Mar 7, 2008 | 11:00 AM
MY 95's Avatar
MY 95
thanks guys, I appreciate it
Old Mar 11, 2008 | 09:21 AM
69mako's Avatar
69mako
So; how did your replacement go?
Old Mar 11, 2008 | 09:27 AM
MY 95's Avatar
MY 95
I was planning to do it tomorrow but my wife just took the day off work now I dont know if I will have the time........it will definitly be this week and I will let you know......Thanks
Old Mar 12, 2008 | 09:58 AM
MY 95's Avatar
MY 95
I just did it and it took and an hour and 45 with several stiops........tghanks to you guys for the cheering section. One minor issue is that when the alarm goes off the key wont shut it off.......hafta work on that......
Old Mar 13, 2008 | 06:11 PM
69mako's Avatar
69mako
I can tell by your miss spelled words that you took my advice and had a few brews with the job
To Have to replace my outer door handle. Any pointers????
