fuel pressure
Old Mar 14, 2008 | 02:00 PM
alecracing's Avatar
alecracing
Default fuel pressure
What is the factory fuel pressure setting for 1987 L98
Old Mar 14, 2008 | 02:07 PM
alecracing's Avatar
alecracing
I also got a 160 thermostat and they sent it without a gasket Am I to believe that there is no gasket between the thermostat housing and intake manifold
Old Mar 14, 2008 | 03:24 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
rec with stock injectors is 38 - 42 psi......I would set it on the high end.
Old Mar 14, 2008 | 04:05 PM
staugur's Avatar
staugur
Yes there is a gasket but I've never got one with a tstat.Go over to Arts corvette parts and pick one up.
Old Mar 14, 2008 | 08:04 PM
RRT vette's Avatar
RRT vette
I have my 86 set at 40 psi vac connected with a adjustable FPR. There is no gasket around the t-stat in the L98 like there is on the LT1. There is a gasket that fits the shape of the t-stat housing thou.
Old Mar 15, 2008 | 11:30 AM
alecracing's Avatar
alecracing
Thanks guys
set fuel pressure to 42, at 38 it was pinging after shift into second
To fuel pressure
