Sensor identification
Old Mar 16, 2008 | 12:18 AM
Pizzano's Avatar
Pizzano
Default Sensor identification
1988 there is a sensor in the head between 1-3 spark plugs, looks like the connection is a green wire with white tracer, looks somewhat like a knock sensor, but I know it isnt that, any ideas.
Sensor looks intacked , but the sensor connection to the Green white tracer wire is broken, do they have connection replacements for these.
Thanx folks
Old Mar 16, 2008 | 01:51 AM
BAM92's Avatar
BAM92
If it is in the head, sounds like a coolant sensor. Haven't had a L98 in years so I am guessing. On Ebay they sell pig tails.
Old Mar 16, 2008 | 02:19 AM
Pizzano's Avatar
Pizzano
It has a ceramic nipple for the connector to attach to just like a knock sensor.
I looked through the manual and cant find anything.
Old Mar 16, 2008 | 04:08 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It's the coolant switch for the Aux Fan. It is the same connector as the Knock Sensor and they are available.
Old Mar 16, 2008 | 04:42 AM
Pizzano's Avatar
Pizzano
Thanx, ya I found it in Ecklers, I dont need it hooked up due to the fact that the fans are hooked up to run as soon as the ignition is turned on.
Thanx again folks
Old Mar 16, 2008 | 04:57 AM
RRT vette's Avatar
RRT vette
Old Mar 16, 2008 | 08:22 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I picked up one at the local auto parts store. Here's a small pic of it.
Old Mar 16, 2008 | 08:48 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Thanx again folks
JMO but hard wiring to come on with the ignition is not a great idea. Your engine won't warm up as quickly as it should and it will draw more on your electrical system than need be. At least put the aux fan sensor back to work based on coolant temp. You can get a sensor to go between 1 and 3 plugs for @ $15. They are available for several on/off temps. My main fan comes on at 226* controlled by the ECM. My aux fan come on at 200* and off at 185* controlled by the sensor. This arrangement is working well and I never have high temp issues.
To Sensor identification
