Shift Light
Old Dec 10, 2001 | 02:30 PM
Dave-T's Avatar
Dave-T
Default Shift Light
Can someone please tell me where I can buy a shift light and who has the best one.
Thanks,
Dave
Old Dec 10, 2001 | 02:42 PM
AS84's Avatar
AS84
Default Re: Shift Light (Dave-T)
I bought the autometer prolite. Go to autometers website and you'll see it there. I like it because it is small and you can easily change out the rpm pills.
Old Dec 10, 2001 | 04:18 PM
GRX's Avatar
GRX
Go here: http://harlan.sketchy.net/store/store.html , he has a rpm shift light that doesn't need 'pills'. It also increments in 100rpm steps.
Old Dec 10, 2001 | 07:33 PM
RichS's Avatar
RichS
Default Re: Shift Light (GRX)
I also recomend the Harlan light. Works great!
Old Dec 10, 2001 | 09:17 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Dave, Panuzzo had one, he gave it to me and then I gave it to Edgar, John may even have it back now, I don't know.
Old Dec 11, 2001 | 11:53 AM
Gonzo's Avatar
Gonzo
Default Re: Shift Light (Mr Mojo)
Hey
I also have thought about it, but am not sure what the benfits are?
And a quetion for Mojo, if its a good idea why did you guys pass it around and not keep it?
Gonzo
Old Dec 11, 2001 | 12:07 PM
scorp508's Avatar
scorp508
.... but am not sure what the benfits are?
Well, the light allows you to keep your focus in front of the car, intead of watching the tach. Also you can set the light to come on a couple hundred RPM before your most beneficial shiftpoint. By the time the light comes on, you react, and shift the car, you will be right on. :)
Old Dec 11, 2001 | 12:51 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: (scorp508)
I have a Harlan light, not yet installed.
Old Dec 11, 2001 | 03:07 PM
Gonzo's Avatar
Gonzo
Default Re: (Vette92)
Ok I looked at the Harlan site (thanks). Where do you mount it in a C4 so its functional and does'nt look bad????
Gonzo
Old Dec 11, 2001 | 03:23 PM
GRX's Avatar
GRX
Default Re: (Gonzo)
I've seen them mounted in the air vent...behind the louvers.
Old Dec 11, 2001 | 04:14 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: (Gonzo)
Here is Hutch's install page...
http://hashmarks.com/ShiftLight/index.html
Old Dec 11, 2001 | 05:07 PM
Hammer's Avatar
Hammer
I had my harlan hooked up with an electrical clip. I only use it when at the track, when I am not racing a unhook it and leave it in the glove box.
Old Dec 11, 2001 | 06:55 PM
Red Rocket's Avatar
Red Rocket
Have the Harlan shift light mounted in the A/C vent. Has worked great with no problems the past year.
[Modified by Red Rocket, 4:56 PM 12/11/2001]
Old Dec 11, 2001 | 07:10 PM
RatRacer's Avatar
RatRacer
Default Re: Shift Light (Red Rocket)
Dean, what wire did you get the tach signal from?
BTW, we are going out to the Motorplex Saturday if the weather cooperates.
[Modified by Cam Potter, 5:11 PM 12/11/2001]
Old Dec 11, 2001 | 07:18 PM
jpee's Avatar
jpee
Default Re: Shift Light (Gonzo)
Hey
Gonzo
gonzo.. I had it when I had a 6 speed Camaro.. when I sold the Camaro, & bought the Vette I didn't need the shift light as the Vette is automatic, and I just set the shift points with my Hypertech...
If I still had a 6 speed car I'd have a shift light in it... Like Scorp says.. just set it 200 rpm less than you want to shift at, & by the time u see the light & react you are shifting right on the money..
Old Dec 11, 2001 | 07:47 PM
Gonzo's Avatar
Gonzo
Default Re: Shift Light (Red96Coupe)
Hutch's web site is Great. I had not seen it before but Nice work :smash: :smash:
Gonzo
Old Dec 11, 2001 | 08:07 PM
Red Rocket's Avatar
Red Rocket
Default Re: Shift Light (Cam Potter)
Cam-
Hooked my shift light to the turn signal wire. The shift light blinks with the turn signal but is no big deal. New exhaust is being installed this weekend so I will not make the test and tune.
To Shift Light
Old Dec 12, 2001 | 12:30 AM
Gonzo's Avatar
Gonzo
Hey John thanks for the response, makes sense as usual.
another question, I looked at the light and the install, How tough is it to do, considering that I'm not a mechanic. Can a somewhat mechanicalinclined person with somewhat limited tools do this or would I be ceating a horror, i.e my dash in pieces and wires running everywhere. I do have a very good mechanic I trust complety with my car, honest and bright.
Try it or let an expert do it.
Gonzo
Old Dec 12, 2001 | 12:58 AM
Mr Mojo's Avatar
Mr Mojo
Hey
Gonzo
Gonzo, I shift by ear(really!) The way I see it, you still have to react to the light. When I hear the engine, I know exactly when to shift. That's just me, doesn't make it wrong for someone else.
Old Dec 12, 2001 | 01:18 AM
powerslide91's Avatar
powerslide91
Cool tip, thanks for the link! I like the hidden aspect of it. One question, I have seen it mentioned several times about the factory tachs not reading accurate. I see that this shift light splices off the tach signal on the firewall, so does it suffer the same inaccurate issue or is the root of the problem in the tach itself? Also, when people say the tach is inaccurate, what are we talking about here? 5%? 10% off?
Thanks,
Jeff
