Door hatch release not working
Old Apr 2, 2008 | 08:35 PM
guido7834's Avatar
guido7834
OK, one last question. I got the door ajar switches to work, they were stuck closed. Now the door ajar and hatch ajar signals in dash work. Still no courtesy lights when opening doors. I think I have it narrowed down to the courtesy light switches in the door jamb. How do you remove the switches to test them? Any tips I should know? Thanks to all who helped.
Old Apr 2, 2008 | 11:39 PM
Radco10's Avatar
Radco10
you have to pull the door panel loose at the bottom and possibly at the handle tray. Then reach in and try to disconnest the the door ajar switch from its connector. The door switch and the connector will not fit through the hole that the door switch mounts to. See my previous thread on testing the door switch. as far as the connector, this is easy: just put a piece of wire between the two contacts in the connector and then your courtesy lights should come on and the hatch should release. When you checked the courtesy lights with the dimmer switch did they all work? Let me know if jumping the connector works.
Old Apr 3, 2008 | 04:45 AM
guido7834's Avatar
guido7834
No, I am talking about the push switch on the jamb near the hinge. Isnt that the switch which turns the courtesy lamps on and off? I know the black door ajar switch on bottom of door is OK.
Old Apr 3, 2008 | 04:46 AM
guido7834's Avatar
guido7834
And yes, all the courtesy lights work with dimmer switch. Thanks
Old Apr 3, 2008 | 05:29 AM
Wingralf's Avatar
Wingralf
Guido7834, Had same problem other day...it came and went.
The rear hatch door switches if they are not working and the interior lights are not working when doors are openned then follow as Yoitsmatt posted on step 2.
Your inside lights and door switches will work with dimmer switch, even the timer reley not grounded. a good way to check to see if you have a ground issue is the drop the pass side lower carpet under dash and check the light there for PoS(+) voltage on both wires if ya have it on both wires to the light the ground is bad. Becareful with the door jam switches they are easy to break. I just set the alarm opened a door set off alarm (guessing the alarm goes thru these same switches) and didn't go any further with them.
Push switch on rear hatch is just a hatch ajar switch i thought
Old Apr 3, 2008 | 06:35 PM
guido7834's Avatar
guido7834
Thanks wingralf, now how do we fix the bad ground, assuming that is the problem?
Old Apr 4, 2008 | 10:08 PM
lenbal's Avatar
lenbal
Be real careful there is a metal plate inside the door panel VERY IMPORTANT PIECE -- unscrew one bolt and put a small screw driver or wire in to hole to hold the plate...same deal on the the bottom bolt, actually we used long thin sheet rock screws to hold the plate. Didnt work like we thought it would mine dropped, got real lucky it landed near the water hole at the bottom of door. Fished it out with a magnetic screw driver unplugged the switch and did put a wire between the inside connection, acutally I let Gordon Killebrew do it... C 4 guru -- the lights came on so we knew it was the switch - took off the passanger door switch put that in and lights work.
Must be a short some where i have to find - lights come on while drriving when it hit a bump or something - could be the open wire on passenger side hitting something -- but they work ..
So all these words and the answer to your question is becareful of back plate when your taking out the switch -- you will need it to put back new one -- put a wire in the 2 holes on the inside plug if lights come on it is your door switch...
since my plate dropped i am going to use fishing wire , put a weight on it drop it down tie on plate pull it up, fish around and get lined up after fighting with plug and put back together ---easy, just take your time
Len
Anyone know where to connect high beam lever by the blinker switch at top of column and bottom connection
Thx inadvance
Len
Old Apr 5, 2008 | 07:26 AM
guido7834's Avatar
guido7834
I am confused here. We seem to be talking about two different switches. Does the door ajar switch turn on the lights or just illuminate the warning on the dash? Or does the push switch at the door hinge side turn on the lights when the door is open? Thanks.
Old Apr 5, 2008 | 08:04 AM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
I kinda have this same problem, except the only thing that dont work on mine is the door button, my console button works good, and all my lights operate properly.
its not a huge deal so I never got into it that deep, this guys problem is more of hassle than mine.
Old Apr 5, 2008 | 08:14 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Interior%20Lights.pdf
http://members.shaw.ca/agent86/Hatch%20Release.pdf
Old Apr 5, 2008 | 09:05 AM
lenbal's Avatar
lenbal
Short answer this time on a 95 the door button controls, console, door panel lights, rear mirror courtesy light ( if you have them ) and security entry light on dash.
Door hatch is linked in there some where but you didnt indicate a problem with that or I didnt see it -- it opens the hatch and lights will come on.
Your interior light dimmer control switch dims or brightens - dash and door lights - for a 95 it is the door switch - as I said last weekend our club had Gordon Killbrew at one of our garages and he worked on my car....thats how I know this ....again for a 95
Len
Old Apr 5, 2008 | 09:32 PM
Hooked on Vettes's Avatar
Hooked on Vettes
On your year vehicle, in order for either of the two hatch release switches on the back of the door panels to work, the Courtesy Lamp Delay timer must operate properly.
When you open either door, the door pin switch located in the A pillar by the front of each door hinge sends a ground signal to the Courtesy lamp Delay timer.
The timer then closes a solid state relay which provides a ground for the courtesy lights so the lights turn on. It also provides a ground for the two hatch release switches so they can engergize the Hatch Release Relay.
Because the Courtesy Lamp Delay timer isn't working, the hatch release switches have no path to ground. The hatch release button inside the center console works because it doesn't use the same circuit path as the two door switches. For the center console hatch release button to function, for an auto trans. the shifter must be in park or neutral. For a manual trans. the emergency brake must be engaged.
Agent 86 posted the schematic showing the Courtesy Lamp Delay timer.
If the Courtesy Lamp Delay timer is bad, you can buy a replacement or bypass it. To bypass it at the Courtesy Lamp Delay timer connector, you cut the white wire at Pin A and cut the two white wires at Pin D. Solder the three white wires together. This will cause the courtesy lights to come on when the doors are opened and go out when the doors are closed. There will be no delay time out for the courtesy lights.
Old Apr 6, 2008 | 07:05 AM
  #33
guido7834's Avatar
guido7834
Thank you, thank you, thank you, Hooked! I think you cleared it up now. Will try to replace delay timer.
Old Apr 6, 2008 | 06:40 PM
  #34
guido7834's Avatar
guido7834
Hooked, where exactly is the courtesy timer relay? Looked behind the driver info panel and couldn't locate.
Old Apr 6, 2008 | 06:42 PM
  #35
guido7834's Avatar
guido7834
Anyone?
Old Apr 6, 2008 | 07:50 PM
  #36
Hooked on Vettes
You need to remove the black plastic foot well panel that contains the courtesy light on the passenger side.
The timer is taped to a wire harness behind the dash. Some people drop the ECM down for better access. The ECM (silver colored metal box) is held in place by two nuts. Once the nuts are removed you pull it down.
http://forums.corvetteforum.com/show...courtesy+light
Old Apr 6, 2008 | 07:54 PM
  #37
guido7834's Avatar
guido7834
Thank you!
Old Apr 6, 2008 | 08:39 PM
  #38
Hooked on Vettes
