87 having issues when removed from storage
Old Mar 29, 2008 | 06:05 PM
hammerdown72's Avatar
hammerdown72
Default 87 having issues when removed from storage
PUlled my 87 out of storage the other day. It has been sitting for about 5 months. Ran a bit rough, took it out on the highway and discovered there is little if any power at all. It started running a bit rough prior to it going in storage. Matter of fact, went from 22-24MPH down to about 5 or 6. But I didnt want to mess with it at the time so I put it away for the winter.
Drove it for about 30 minutes. Tail pipes were ice cold, revd the motor some, nothing coming out of the tail pipes at all. I have an idea what the problem may be and a fix, please give me your diagnosis and a quick fix.
Thanks in advance,
Steve devos
Old Mar 29, 2008 | 06:55 PM
jfb's Avatar
jfb
Clogged catalytic converter. Install new converter.
Old Mar 29, 2008 | 07:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Mar 29, 2008 | 08:10 PM
hammerdown72
Id like to just cut these precats and cat off. Im sure there are many threads on this, I just hvent looked yet. Cut off? or Replace? What would you do?
Steve Devos
Old Mar 29, 2008 | 08:24 PM
NHRalph's Avatar
NHRalph
Steve Devos
A lot will depend on where you live and how they do inspections. You can get a 'y' pipe without the pre-cats and then get a high flow cat. Keeps everyone happy, except California where no one is happy!
Old Mar 29, 2008 | 08:28 PM
hammerdown72
Im in Iowa. Is it possible to cut each off and weld some tubing in place of the pre cats and cats?
Im a rookie so forgive me.
Steve Devos
Old Mar 29, 2008 | 08:45 PM
c4cruiser's Avatar
c4cruiser
Do you have to have your cars run trhu a smog check? If so, then removal of the cats will cause the car to fail the test.
You can remove the pre-cats and weld pipe in their place. I would still run a main cat in the stock position. Replacement high-flow cats are available and easy to install. Make sure you get one that has an AIR tube to connecto to the existing air pipe. You can also get a front Y-pipe without the pre-cats from Mid-America or other accessory suppliers.
If you go to a muffler shop and ask to have the cats removed, you may get a quick refusal. Removal of the cats (either removing functioning ones, or removing them and not replacing them) is a violation of federal law and a shop could get a huge fine if they get caught. It's around $10 to 15 thousand dollars
The main cat is not welded, there should be a 3" clamp at the frnt of the main cat and there is a ball-and-socket connector at the rear of the main cat. You could weld in a piece of pipe but you have to fabricate a hangar strap to the front hanger just in front of the main cat.
Old Mar 29, 2008 | 09:21 PM
hammerdown72
Is it likely that the precats and the main cat are all plugged at the same time?
Steve Devos
Old Mar 29, 2008 | 09:26 PM
87Beast's Avatar
87Beast
If you want to go with a cheap and quick solution: Just chisel out the crap from the precats, which is what usually what cloggs the main cat, replace main cat if you have emission testing or if it looks shot. This way you don't have to mess with a welder and such.
Old Mar 29, 2008 | 09:28 PM
hammerdown72
How can I remove the precats?
Steve Devos
Old Mar 29, 2008 | 09:43 PM
Bob CTS's Avatar
Bob CTS
Steve Devos
With a saw? When I got my 86 the precats were removed and a section of pipe cobbled in, looked like azz, the main cat was gutted. I purchased a used Y pipe w/ precats and installed a new main cat and the performance of the engine was so much better, ran much smoother.
If I were you I would drop the exhaust and take a look at what the problem is. Not hard to drop at all.
To 87 having issues when removed from storage
