Replacing c4 boot cover?
Old Apr 3, 2008 | 11:55 AM
completelyvetted's Avatar
completelyvetted
Default Replacing c4 boot cover?
1987 Automatic Shift, not manual:
Does anyone know what steps are necessary to do this? I just go the new black leather boot cover and realized I would probably need to remove half the pieces on the middle console to do it.
There are also four small holes at each corner of the new boot cover, any idea what these are for?
Old Apr 3, 2008 | 11:58 AM
85WHITEZ51's Avatar
85WHITEZ51
the 4 holes are for the screws that mount it to the center console. Not sure the year of your car or if auto/manual.
I just did nine when I did my interior swap for an 85 auto. All in all it is not to hard if you take your time but you do have to remove the center console and the center console frame. Be carefull when removing your shifter **** if an auto as it requires the removal of a c clip. if you don't hold it tight it will fly away :-)
Old Apr 3, 2008 | 12:23 PM
Demonic85's Avatar
Demonic85
You have to remove the cig lighter and disconnect it on the backside. Its easier if you put the car in neutral.
Old Apr 4, 2008 | 01:34 PM
completelyvetted
Default Thanks
It is an automatic, 1987 coupe.
Remove the cover plate and center console?
Old Apr 4, 2008 | 01:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yes and no:
-pry out the shifter button
-use long nose C-clip plyers to remove the C-clip inside the shifter ****
-remove the shifter ****
-remove the screws holding the shifter cover plate, including the one inside the center console
-once you lift the shifter console up off the shifter stick, flip it over to see how the shift boot is attached
-remove the old boot, install the new one and put it all back together
Old Apr 9, 2008 | 08:30 AM
completelyvetted
Default C-Clip removal?
if you don't hold it tight it will fly away :-)[/QUOTE]
How does the automatic shift **** come off, before getting to the C-Clip? Unscrew it by hand?
Some have said it may not be necessary to remove center console panel but I disagree, there are no screws present on the outside of my shift boot right now.
Old Apr 9, 2008 | 09:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I can't see removing the console trim without first removing the gauge trim, center trim and the loaf of bread.
Old Apr 9, 2008 | 09:51 AM
Demonic85's Avatar
Demonic85
Some have said it may not be necessary to remove center console panel but I disagree, there are no screws present on the outside of my shift boot right now.[/QUOTE]
The only thing holding it on there is the C clip, its on there really really tight though. The manual shift **** screws on but not the auto.
Old Apr 9, 2008 | 10:55 AM
Muffin's Avatar
Muffin
Shift ****--Gently pry up on the center button. It will come off without effort. Look down the exposed recess in the ****. See a 'C' clip. Remove clip, lift ****.
To change the boot you must remove the console cover. Can't remember how many screws but do recall there are two in the console. With all screws out and the shift in ,maybe Drive,lift the cover. See the comment about the lighter plug. Turn the cover over and see the 4 screws that hold the boot. Caution: those 4 screws are in a metal speed nut glued to posts on the cover. After so many years the plastic becomes brittle. Exercise caution.
Two guesses as to who just went thru all this.
Old Apr 16, 2008 | 11:40 AM
completelyvetted
Default Thanks for all the posts!
Thank you for the reply
Old Feb 25, 2009 | 11:53 PM
burmeister's Avatar
burmeister
very helpful guys.... one question the button to the shifter you pop that off and then the c-clip is in there? thanks rob
Old Feb 26, 2009 | 06:23 AM
Epimax's Avatar
Epimax
Yep! Once you pop off the button, you'll see the c-clip attached to the shaft... Watch out, or it will fly away!
To Replacing c4 boot cover?
