Dead 93 LT1 need help
Old Apr 4, 2008 | 06:38 AM
jimijam95's Avatar
jimijam95
Default Dead 93 LT1 need help
I got a 1993 LT1 for Christmas, my 1st Vette... LOVE IT !!! Recently on my way home, down shifted to 3rd to make a turn and she died on me, like it was running out of gas. It took four tries before she refired, only a couple of miles from home, I got here, she was spitting and sputtering. The next day, she won't start... no I didn't wash the motor. Any ideas of what's wrong with her?
Old Apr 4, 2008 | 07:05 AM
geogolf's Avatar
geogolf
Default car
sounds like optispark if it will crank and not start.does car turn over or is it dead when you turn key
Old Apr 4, 2008 | 08:05 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If the car turns over but won't start check for fuel and spark.
My 92 did something similar, sputtered and died on the way home from work. I replaced the coil and she ran well until the waterpump took out the opti.
Old Apr 4, 2008 | 08:20 AM
aminnich's Avatar
aminnich
Opti, ignition module, coil, ecm, fuel filter, and more items are all possibilities. Scan it for codes first and see what it can tell you.
Old Apr 4, 2008 | 10:05 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Check out the reply I gave you in the General section.
Old Apr 4, 2008 | 09:56 PM
jimijam95's Avatar
jimijam95
that's where it sounds like, that's alot of $ right?
Old Apr 4, 2008 | 09:57 PM
jimijam95's Avatar
jimijam95
so what the bottom $
Old Apr 4, 2008 | 09:58 PM
jimijam95's Avatar
jimijam95
so what's the $ now?
Old Apr 4, 2008 | 09:59 PM
jimijam95's Avatar
jimijam95
no it turns over, now how much $
Old Apr 5, 2008 | 09:57 AM
aminnich's Avatar
aminnich
Wow! Four repeat posts asking how much money. Somebody anxious?
Jimijam, I have no idea how much money. Just send me the car and $10K cash, I will call you when it is ready to be picked up. I should add I do great work and my warranty is just as long as my driveway.
Waitng to hear from you.
Old Apr 5, 2008 | 11:24 AM
willmitchell5's Avatar
willmitchell5
8th Gear
Default Scan
HAve the car scanned. When it died out on you it probably went into "limp home mode" and is still in that mode. The money is never as important as taking it to a good vette shop. You will spend less money with someone that knows what they are doing and looking for than with some ordinary shop that will guess and throw parts at it. Remember, the cheap will cost you plenty.
Old Apr 5, 2008 | 02:03 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I would ask who you bought it from if they washed it. I would suspect Opti, as it is a fragile piece, trust me.
Take one plug wire off and see if you at least have spark. This will tell you ECM and coil are working, not necessarily the Opti. The opti will send a spark out, but when degraded or breaking down it will send a spark where ever. Think of a glass of water and you are looking through it, that is what the opti sees too when it has water in it, so it will throw a spark wherever.
Old Apr 5, 2008 | 10:45 PM
jngizzi's Avatar
jngizzi
Same thing happened to an '88 I had many years ago. Classic signs of a bad ECM chip.
To Dead 93 LT1 need help
