heads.....need quick help
Old Apr 5, 2008 | 01:28 PM
GS345's Avatar
GS345
St. Jude Donor '11
Default heads.....need quick help
I have a broken spring cup in my heads. I have removed the spring.......now how do I get the oil seal out to replace the cup??
TIA>
jeff
Old Apr 5, 2008 | 02:22 PM
STL94LT1's Avatar
STL94LT1
Just use a pair of pliers and pull it off. I would replace with a new seal.
Old Apr 5, 2008 | 03:38 PM
GS345's Avatar
GS345
St. Jude Donor '11
OK got it off and got the new ones. now Im really confused. the ones I pulled off looked to be compressed onto the shaft (holding them on) and the new ones just slide over (really sloppy). Is there a tool to crimp them on? or am I missing something?
jeff
Old Apr 5, 2008 | 05:44 PM
GS345's Avatar
GS345
St. Jude Donor '11
Old Apr 5, 2008 | 06:05 PM
STL94LT1's Avatar
STL94LT1
They should just press on.
Old Apr 5, 2008 | 06:12 PM
GS345's Avatar
GS345
St. Jude Donor '11
Thats what I thought. But they go on really sloppy. If you put it on and turned the head over, they would fall off. AGGHHH. The only thing I am wondering is if they are different since they are 'not stock' I bought them from More performance.??? But you would think the shoulder is the same??!!??
jeff
Old Apr 5, 2008 | 06:36 PM
GS345's Avatar
GS345
St. Jude Donor '11
OK. the one in the center is the one I pulled off the others are the 'right ones'
Old Apr 5, 2008 | 06:51 PM
STL94LT1's Avatar
STL94LT1
Hmmm, looks like your heads have been machined for a smaller seal?
Old Apr 5, 2008 | 06:53 PM
GS345's Avatar
GS345
St. Jude Donor '11
I'm beginning to wonder. This is the first time I have torn them down to this point. How or where would I start in getting the right ones?
Old Apr 5, 2008 | 07:27 PM
Zix's Avatar
Zix
Mine look exactly like the ones on the right and left in your pic, I have no idea about the one on the middle!
Old Apr 5, 2008 | 07:54 PM
GS345's Avatar
GS345
St. Jude Donor '11
My springs are double springs. Could/would that make a difference??
Old Apr 5, 2008 | 08:04 PM
STL94LT1's Avatar
STL94LT1
Will the smaller spring fit over the new seal. If not, your heads probably have been machined to fit the smaller seals.
From what I could find. The stock guides should measure .556
Old Apr 5, 2008 | 08:54 PM
GS345's Avatar
GS345
St. Jude Donor '11
Stock being .556. Mine have been turned down to .530 with 11/32" valves. Comp cam pt # 503-16.??????
To heads.....need quick help
