Help
Old Apr 15, 2008 | 03:21 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
1. Get the FSM
2. Learn to use the search function.
3. Save $1000 for regular maintenance items that will cost $$$.
4. Be satisfied with what you have you are far from experienced enough to handle what you have and do not need more power yet. Doing burnouts or even thinking about it at your age is a recipe for disaster or huge tickets + loss of license.
5. Stay in school and pay attention in English class. The FSM is a tough book to read (did I mention BUY ONE?).
Old Apr 15, 2008 | 03:36 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I'm sure you are excited and want her to run fast. Right now you are probably just over 160hp at the rear wheels.
Change all the fluids - Oil, trans, rear, brake, etc.
Change the plugs, cap, rotor, coil, ICM
Can't remember if the 90 had a frisbee or not (its a big circular disk attached to one of the pulleys, I forget which one my 88 is long gone) if so get rid of it.
Get a throttle body rebuild kit (its a bunch of gaskets), take off the throttle body and clean, clean, clean.
Read the FSM daily!
Last edited by jaa1992; Apr 15, 2008 at 03:37 PM. Reason: Forgot he had a 90 for a minute
Old Apr 15, 2008 | 04:41 PM
CFI-EFI's Avatar
CFI-EFI
The coil and ICM are not maintenance items like the rest. Leave them alone unless they test to be faulty. The cap and rotor should be inspected before replacement.
RACE ON!!!
Old Apr 15, 2008 | 04:52 PM
Demonic85's Avatar
Demonic85
Originally Posted by Iroc57
If it runs now leave it be
Drive it and be the coolest kid in school and as you get more seat time then you can mess with it.
(more root beer)
best advice right there. Driving it will also give you some time to think about which direction you want to go with mods, not to mention saving up some money to do it.
Old Apr 15, 2008 | 04:58 PM
Square's Avatar
Square
Originally Posted by yourboy
.....my corvette but it dosent have alot of power it cant even burn out off the line but hes got a shop to do it at so name your suggestions.
Huh??????
A bone stock L98 should easily be able to spin the tires from a dead start!
In stock form you should have around 200RWHP and over 300RWTQ
Where are you located?
It sounds like you need a tune up, not mods.
And....not to offend you...but, please do pay attention in english class. First impressions are important, and your command of language plays a large part in that.
Old Apr 16, 2008 | 01:17 AM
Master__Shake_'s Avatar
Master__Shake_
Originally Posted by Square
Huh??????
Where'd you find those numbers? In a hypertech corvette manual?
L98s are lucky to get 140-160 at the wheels.. even with a couple of mods. Especially automatic..
But you're right about the tires, mine could definitely spin them from a standing start from day one. Maybe he does need a tune.
Old Apr 16, 2008 | 09:23 AM
Square's Avatar
Square
No sir, I got my numbers from the dyno I take my cars to.
I tried to get a baseline dyno, but a modded C1 (heavily modded) that ran before I did, damaged it, so I couldn't get my run.
Here is the dyno from my 86' after I put the TPIS long tube headers and Random Tech High flow cat on the car:
Here is the car on the same dyno after I installed the TPIS "Big Mouth" intake, "Big Tube" runners, ported the plenum and added an adjustable fuel pressure regulator (I think the "smoothing" setting was different on this run/print out):
As a reference, I also have a 99' corvette I bought new, I bought the 86' in 2004. At the same place, it's dyno looked like this (bone stock, 10K miles):
For both cars, allowing roughly 15% drivline loss for the 99' (it's a 6 speed), and 17% loss for the 86' (automatic) will get you back to numbers that look very much like the factory ratings (235HP, 330TQ for the 86' and 345HP, 350TQ for the 99').
My 86's number are similar or slightly lower than other cars on the dyno I use. What numbers have you been seeing at the dyno?
Old Apr 16, 2008 | 12:36 PM
Master__Shake_
But as you stated, there were modifications to your '86 before the posted dynoes.If running an all stock L98,
you won't have enough intake OR exhaust to break 200.
The headers and cat are what gave you the power.
Nice to see a dyno chart of the nearly-stock powerband, though. It really does fizzle after 4,000 RPMs..
Old Apr 16, 2008 | 02:22 PM
yourboy's Avatar
yourboy
what would i have to do to give it a tune up my self???? and i live in Detroit.I also have the fsm for an 86 and an 87 but some stuff is different like it took years to find the aldl connector. but ime going to check the timing today.I changed the fluids except for the abs but i haven't started on the electrical.
Old Apr 16, 2008 | 02:50 PM
CFI-EFI's Avatar
CFI-EFI
The ALDL is in the same spot for all C4s, but "it took years to find the aldl connector"? Do you know HOW to check the timing? Do you know where the ESC connector is?
RACE ON!!!
Old Apr 17, 2008 | 08:34 AM
yourboy's Avatar
yourboy
RACE ON!!!
yes i have the timing gun looking thing
Old Apr 22, 2008 | 12:06 AM
yourboy's Avatar
yourboy
well i guess no 1 likes my thread any more but ime taking your guys advice ime going to paint it then take the engine out and rebuild it it only has 75k on it but it needs it itll be good for it and maybee do some minor mod while ime at it. Any ideas?? But has any 1 got theres paint? if so how much? I was thinking i will try to get this paint off my self some how.
Please reply?
Old Apr 22, 2008 | 11:12 AM
  #33
CFI-EFI's Avatar
CFI-EFI
Once again in English. Sentences start with capital letters and end with punctuation. Is all that I quoted above just a single thought, as in a single sentence? "no 1"??? How about, no one? "No 1" is often used to mean, number 1, with no. being the abbreviation for the word number. What is "ime"? It appears several times so I'm guessing that it isn't just a simple typo.
Why rebuild an engine with only 75,000 miles on it? You say it needs it. What tells you that? Is it exhibiting problems?
I see a capital letter and ending punctuation. YEA!!! But what the hell does it mean???
Quit day dreaming about the car and get into a remedial English class. Spend your spare time on home work. Any 15 year old ought to be able to construct and write simple sentences.
RACE ON!!!
Old Apr 22, 2008 | 11:48 AM
  #34
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Yeah......you are annoying many crabby old men.
Old Apr 22, 2008 | 12:58 PM
  #35
yourboy's Avatar
yourboy
It's leaking oil and I cant figure out where it's coming from. I thought it was coming out of the manifold but it wasnt, I sprayed the engine down and still could't see where it was coming from. Yea I wanted to know if any one has gotten theres painted.
Old Apr 22, 2008 | 01:26 PM
  #36
Grimreaper's Avatar
Grimreaper
Stop worrying about the paint. It looks good in your picture and you are 15 years old, trust me you will have a chance to repaint the car after you wreck it.
Now about the oil leak, you need to put the car on some ramps and craw under it to find where it is coming from. Remember the key to finding oil leaks is to have the engine clean.
Old Apr 22, 2008 | 02:06 PM
  #37
oldblu's Avatar
oldblu
8th Gear
From the photo, you've got one helluva sweet first ride. IMHO, polish it, tune it, and fix the oil leak. You're going to need all available cash for tickets once you reach legal driving age.
To Help
Old Apr 22, 2008 | 02:37 PM
  #38
jmrl98's Avatar
jmrl98
Yourboy, if worse comes to worse, there is a kit you can buy that contains a dye and a UV lightsource that shows the dye. Dye in the oil, start her up and watch for the fluorescent color, and you can trace back your leak.
Old Apr 22, 2008 | 08:07 PM
  #39
CFI-EFI's Avatar
CFI-EFI
So to cure an oil leak you want to overhaul the engine? That would be like amputating your right arm because you had a hang nail. That is a bit of overkill and not a sign that "it needs it".
"Yea"? Do you mean their's, possibly???
Remedial English!
RACE ON!!!
Old Apr 22, 2008 | 08:13 PM
  #40
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
You're out of your mind.
My basically stock 1990L98 dynoed at 223HP at the wheels.
