So how much does it weigh now?
It would very hard to list everything but here is probably 90% of what I have done. head lights are very heavy by the way I wanna say like 25 pounds+ for the pair. I am looking at a light weight option there. I have a lot missing. Forgot to mention I have a lexan top. I run a single 3 inch exhaust with no cats. ton of weight came off there. its all the little stuff. the entire radio actually weighs a good chunk. headers. Horns, cruise. air. a/c I only run one manual seat, soon to be a racing seat. the rear interior is quite heavy... front is not nearly as bad on the 88. dash pad, dash panels. I know anyone with the stock 88 wheels can save 6 spounds by pulling the centercaps. light weight wheels and tires also help, but i only sort of have that with c5 wheels... kuhmo v710s are on average 4pounds lighter than street tires. I have a huge box with all the crap I have taken out and the box is very heavy. as you can tell, I am scatter-brained but I think I hit the high points. Future mods- (QA1 coilovers... not a steel bodied unit) Power window removal, lexan hatch, carbon race only hood (ton of weight in the stock hood with all the hardware), c5z wheels or c5 rears all the way around. lightweight battery. After I do a motor swap back to carb or an ls1 swap, there isnt a whole lot more that I can think of. I am sure I missed a few though. I think 2700 is very doable. 2600 was the goal. Ive been short on time so I havent done much in a while. if You are serious about racing. I would get the race only hood from EM and then you can swap your regular hood on and off without screwing with it.weight off the top of the car is ideal. get a lexan top if you dont already have one. Fuel cell is a good idea because you run less fuel and maybe get it move ahead of the axel? reducing the pendulum effect. I havent looking into this but I really should
One last thought... Has anyone done research on which manual trans is the lightest? I am considering all options I suppose
Either the scale was off and the car is heavier, or my 85 is a lightweight, because that means it weighs under 3000 lbs with the heavy rollbar. I dunno..... one or the other I suppose....
This car now is lighter than most 4 cylinder sport compact cars.
I've weighed my car several times, and anything under 2800 lbs is pretty light, under 2700 lbs is stupid light, and getting close to 2600 lbs is nuts.
Details about my car can be found on my site, http://www.mowhineracing.com, but most interior gone, half of the dash gone, no AC, no passenger seat, aluminum driver's seat on fixed rails, some stuff gone under the hood, etc. On a set of Longacre race scales, it is 2900 completely full of gas. If you drop it to 5 gallons (15 gallons @ 6.5 lbs/gallon), thats 2800 lbs. I do still have door beams and all glass.
Corner weights completely full of gas:
718 818
754 611
Any C4 claiming to be 2700 lbs or less is REALLY light, and has to be missing lots and lots of stuff. No disrespect to anyone, but some of the numbers posted here are VERY, VERY hard to swallow, no matter how certified the scale claims to have been.
718 818
754 611
I'm certain the scale that I weighed 2740 lbs on certified. If I go to a few more scales and it reads just that weight, plus or minus 10 lbs, then I'm sure this will be one of the lightest street C4s here. I'm still 140 lbs above my weight loss goal of 2600 lbs, but then I'd have to buy a CF hood, fuel cell, lexan to replace all the glass on the car and gut the doors even more. Fixed windows anyone? We all know how expensive that can be....
-2740
460
That is a LOT of weight to lose. I personally dont see where its coming from .
You have the 350 in it right now, no? I could be wrong but I thought your 383 scattered.
I would guess 540chp at that weight you should be running 10s.
Any idea what your door bars weighed?
at full cage in moly is not going to weight that much. My car only needs a hoop and two down bars made of moly to complete the cage. RIght now the guy that installed everything said it only weighted 46lbs and that is with some extras like swingout bars and spring loaded latches. With it finished it might be pushing 70lbs.
I wish my car was only 2800lbs! But I have a tough time pulling things out of it. Still has the stereo etc.
