So how much does it weigh now?
Interior carpet and all padding are now completely removed except for door panels and will soon be replaced with light auto carpet.
All interior plastic panels are gone, (check F/S sale thread for proof) except for rear view mirrors.
Dash and everything related to it are now completely removed and will soon be replaced with aftermarket guages.
A/C system is gone for good, used shorter serpentine belt rerouted over the tensioner instead of under,
ABS system has been eliminated.
Have manual seats racks, but using still stock seats.
Using a carb system with all the non-essential smog stuff removed. (check sig.)
Using some old 16" Centerline rims with skinnies on the front.
Using clear targa top.
Car still runs and has the street legal items, i.e. headlights, brake lights, mirrors, etc...
My guess would be 2600 lbs. Your guess?
Anymore ideas on weight reduction? I want to have the lightest, street legal C4.
To get to 2600 beans you would need to have lexan rear, lightweight hood, lightweight front runners, race rear wheels. likely aftermarket race brakes on 4 corners, no lights in the thing, and just about everything else gutted out of it to make that sorta weight.
I have seen all out sheetmetal (aluminum cars) weight in and they are still over 2600lbs. IMHO you will not have a street legal car at 2600lbs. Maybe I am wrong but if you do I would like to duplicate whatever you did to get there, unless it gets crazy as I sitll running mine on the street.
do you have any photos of it? Have you weighted the things you removed?
Good luck, weight is the easiest way to quicker times. I just can't force myself ot tear my car apart.
I would say you are down there, but 400lbs worth??? Maybe!!!
Wish I had your car with my motor, trans, and rear.
My '84 with an almost full tank (full minus a 40 mile drive) weighs 3345 without me, on the race track scale. I have my serious doubts on both the 2600# and the 3000# claims.
RACE ON!!!
scales and on two other scales will support what people are saying here.
Incidently, NitrousSam is perhaps the most knowledgeable member on
this board regarding how to achieve weight loss on a C4.
Some old threads
How light is your streetable c4?
Corvette weight by year 84-96
CentralCoaster's graphic based on M Antonick's data in 'Corvette Specs:
1984-1996 Models' (ISBN: 0933534515)
So, how light is your C4 racecar?
http://rides.webshots.com/photo/2863...49400743mPzTcT
http://rides.webshots.com/photo/2506...49400743oMdFhb
I am not disputting anyones claims, but this is what it is.
Wow, that’s pretty cool
not sure what my car weight is but I’m sure is around the 2800lbs range, i have light weight carpet, carbon fiber interior, aluminum heads, sheet metal intake, aluminum rods, light weight hood that’s only 22 lbs, no side crash beams , fuel cell, i rewired the whole car, lexan hatch, i can go on all day, and the car has a narrowed 12 bolt with chromemoly parts. And super light wheels, my fronts are 7 lbs and the rears are only 14 lbs but they are 12 inch wide.
RACE ON!!!
3240 lbs. from your picture + approx. 60 lbs for 10 more gallons of fuel = 3300 lbs.
Still pretty light.
My 88 weighed in at 3130 lbs. with 3/4 tank last time I had it on the scales (each corner).
Oops.
