Tranny gurus step inside....lock-up issues
I'm having overdrive issues (not engaging unitl 65 mph) and I figured, perhaps, it was something with the ecm not allowing the lock-up to engage. However, we adjusted the 4th gear lock-up with the dyno tune, and no change (changed from 47mph to 40mph) . It was then that I realized I also should have a 3rd gear lock-up function (set at 38mph).
The car continues to stall all the way until OD finally engages at 65 mph. I can tell you, it's getting a little frustrating stalling at 55 mph in highway traffic in 3rd gear.
Any of you gurus have any suggestions?
I did the install myself, and all wires/harnesses are indeed plugged in. The speedo reads correctly, so the speed sensor must be working. I have tried adjusting the shifter cable, and haven't seen any changes.
Thanks in advance!
Thanks in advance!
When you say stall, do you mean that the engine shuts off when driving down the highway at 55 mph?
As far as the late shifting, it is possible that you have a governor problem. You can swap the governor from your old trans, and see if it solves it. Before installing it, clean it well with carb cleaner and dunk it in fresh atf. It is unusual for a governor to affect 1 gear only, especially 4th, but I have seen stranger things. Something to try that is free, and may solve it.
I'm right there with you....with the beers, I mean.
When I say stall, I mean the engine revs to a greater degree than the power is transfered to the wheels. Essentially, what I would describe as what a stall converter would do, but seems to be overriding the lockup programming of the ECM, at least in 3rd gear. Maybe I'm just misunderstanding, and this is a normal function...but seems strange in the mid 50 mph's.
Would replacing the governor with the stock one affect any of the other performance aspects, or strengths of the tranny? And, by the way...where the hell is the governer, anyway?!
Other than this issue, this trans is flat awesome; mild shifting under light load, incredible shifting under power. And I'm not afraid to lay the boost on it either.
Ahhhh.....time for a refill!
I haven't had the car on the highway yet, but I was able to run her up, and cruise, at about 57 mph, still without OD engaging. I did notice that the stock large spring rate from original governor was much heavier than the one in the new tranny.
I'm not sure if the improper seating of the cover would prevent the upshift from 3rd...but by not running it on the highway to see if the 65mph shift is still in play I just don't have alot of info.
RACE ON!!!
The 86 (I might have it around some place) probably looks similar.
Can you look at your bin?
Is your coolant temp coming up over 120F or maybe disconnected?
Last edited by QuikZilver; Apr 17, 2008 at 05:19 PM. Reason: English not too good. LOL! Corrected..
I don't have a way to pull the BIN info., unless I can do it with datamast.
