Sensor on oil pan..
Old Dec 13, 2001 | 02:23 AM
GlockLT4's Avatar
GlockLT4
Default Sensor on oil pan..
Since I don't have my service manuals (they are at the shop), anyone know off the top of their head if the sensor on the driver's side of the oil pan is the oil level sensor, or the oil temperature sensor?
Thanks!
I'm making my list of sensors and other small things to replace while the engine is apart.
Old Dec 13, 2001 | 09:27 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Sensor on oil pan.. (Glock'94)
in the pan itself?
My guess is oil level
Old Dec 13, 2001 | 10:09 AM
wheelsup's Avatar
wheelsup
Oil level. :yesnod:
Phil C
Old Dec 13, 2001 | 10:19 AM
Goody's Avatar
Goody
Default Re: Sensor on oil pan.. (wheelsup)
It is the oil level sensor. Got one to replace as well.....cost $35 if I remember right....probably should have contacted 18carfan for it..... :yesnod:
Old Dec 13, 2001 | 11:51 AM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Curtis,
If it's the sensor on the drivers side right above the oil filter then it's the oil temp sensor. I know this because the clip on mine broke and I'm constantly having to climb under the car and plug it in to get my oil temp gauge to work.
Old Dec 13, 2001 | 12:41 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Sensor on oil pan.. (Thumper)
If you refer the the big thing IN THE PAN, looks like a great big nut. That's oil level. If it's in the block it's oil temp.
Old Dec 13, 2001 | 12:44 PM
GlockLT4's Avatar
GlockLT4
Default Re: Sensor on oil pan.. (Nathan Plemons)
Yeah, it goes horizontally in the side of the oil pan.
Old Dec 13, 2001 | 06:06 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
be sure it gets removed before the pan does. I forgot to get mine out and broke it. It was like - hmmm...I wonder why the pan won't come down. Fiddle fiddle. oh year oil level sensor needs to come off. removed it. Its broken. DOH.
To Sensor on oil pan..
