AC Question (UART Failure)
Old Apr 15, 2008 | 12:13 PM
JA94vette's Avatar
JA94vette
Default AC Question (UART Failure)
Hey guys, I have a 94 with the C68 electronic climate control. I have a code 10, UART Failure when scanning the codes set. I know it is a communication problem but my question is...between what? The head unit and the programmer or the programmer and the PCM?
Also, where is the programmer located.
Any suggestions to troubleshooting this problem?
Thanks,
Jeff
Old Apr 15, 2008 | 01:58 PM
pcolt94's Avatar
pcolt94
The programmer talks to the CCM on the serial data bus. If there is no communication, then this will set the DTC 10. The control head communicates with the programmer on its dedicated data lines.
The head talks to the programmer to control the solenoids (vents) and fan.
The programmer talks to the PCM to control the A/C compressor on its own line.
I believe the UART you want to get at is the one in the programmer since that is the one on the serial bus. The programmer is low under the dash on drivers side (I think, have not been there yet) against the wall.
Here is a link for the programmer which might be of future assistance if you have some electronics knowledge.
http://www.batee.com/corvette/acrepa...oard/c68.shtml
You might get lucky and take a shot at cleaning the internal contacts in side the controller head as well as the external ones.
Old Apr 17, 2008 | 09:49 AM
JA94vette's Avatar
JA94vette
The whole problem started when my compressor would not kick on. I thought it was low freon from just sitting but, I checked that and am now getting this code for UART failure. I guess it is probably the programmer having issues sending data to PCM. We'll this is horrible timing since I just got my interrior back together ! Hopefully it will be easier to get to than I think. Thank you very much for the reply and I'll try to follow the instuctions on that site and get things cleaned up!!
To AC Question (UART Failure)
