Timing Cover
Old Apr 16, 2008 | 10:54 AM
Demonic85's Avatar
Demonic85
Default Timing Cover
I need some help with getting these thing off. I've removed all the bolts, pryed all the way around with a screwdriver, beat it with a hammer, it still wont come off. I've spent the last hour trying to get it off. I've never seen such a stubborn motor. Any tips?
Old Apr 16, 2008 | 11:17 AM
joeld's Avatar
joeld
The front cover does not come straight foward to remove. Botom of cover has a "lip" that slips inside the oil pan that holds the front rubber gasket. My experience is to loosen the oil pan is the only way to remove cover. And even then you will have to tilt the cover foward to allow the lip to slip out of oil pan.
Joel
Old Apr 16, 2008 | 11:29 AM
CFI-EFI's Avatar
CFI-EFI
By pulling forward at the top, as explained, you may get away without loosening the pan. I did. Once off, you can trim the seal trough for easier (but not easy) reassembly.
RACE ON!!!
Old Apr 16, 2008 | 12:18 PM
Demonic85's Avatar
Demonic85
I loosened the bolts on the front of the oil pan I still cant get it out
Old Apr 16, 2008 | 01:08 PM
Muffin's Avatar
Muffin
I have never had much luck getting one off without lowering the pan. Second, look just above the two lowest bolts, you will find two locating pins,maybe 3/16 in in diameter. I have always found that prying the top out first is the way to go.
Old Apr 16, 2008 | 01:49 PM
joeld's Avatar
joeld
Remove the first 3 or 4 bolts from the front of the pan on each side. Loosen all the rest about half way. This is not an easy deal with pan on, but it will come off. Also be sure you understand what CFI-EFI was referring to on how to trim front seal. That was a good point I forgot to mention. Front cover has to "roll" out from the top.
Joel
Old Apr 17, 2008 | 12:43 AM
Frizlefrak's Avatar
Frizlefrak
You need to lower the pan a bit. Some have done it without doing this, but it's much simpler if you do. In fact, now is a good time to drop the pan completely and put on the one piece rubber pan gasket and never have to worry about it leaking again.
Are you 100% positive that you've removed all of the fasteners? You can also try slipping a putty knife (carefully) in between the cover and the block to break the old gasket loose.
Now...given that you've pried on it, it may not seal when you put it back on. Check it for damage before reusing it.
It shouldn't be all that difficult to remove.
Old Apr 17, 2008 | 07:43 PM
Demonic85's Avatar
Demonic85
I have pried all the way around the cover and its still on there. I'm thinking about just breaking it off and the pulling the rest out with pliers.
Old Apr 17, 2008 | 11:37 PM
Demonic85's Avatar
Demonic85
ttt still cant get this off
Old Apr 17, 2008 | 11:43 PM
Frizlefrak's Avatar
Frizlefrak
Did someone RTV the crap out of it? I can't imagine why it wouldn't break loose unless someone used something like JB Weld to put it on. The gaskets on these are thin, and even the cleanup is easy.
At this point, breaking it off may be the answer. SBC timing covers are easy to come by.
Old Apr 17, 2008 | 11:45 PM
Syclone354's Avatar
Syclone354
pry close to the dowel pins to start, they fit very tight sometimes and make it difficult to get off.
Once you have it off, take some tin snips and cut the inside corners off of the cover where the seal sits in it. That way you can slip the cover in and out without even taking one bolt on the oilpan loose.
Old Apr 17, 2008 | 11:47 PM
Demonic85's Avatar
Demonic85
Seriously i've never seen anything like this in my life. I had a '77 C10 with 160K miles on it, never rebuilt and the cover came off with little effort. Guess i'm getting me of those fancy chrome covers
Old Apr 18, 2008 | 12:09 AM
Frizlefrak's Avatar
Frizlefrak
Please reconsider....the chrome ones have a tendency to distort and leak. And given the amount of work invovled removing it, I would advise staying with a stock cover.
I'm stumped on yours. The cover on my 140K mile 84 came over very easily, even after the harmonic balancer committed suicide and bored a nice hole in the seal. I suspect yours has been off before, and someone decided to use something seriously sticky to reinstall it.
When it does finally come off, let us know what you encountered....I'm quite curious. I've removed dozens of these over the years and never had one stick this badly.
Old Apr 18, 2008 | 12:38 PM
Demonic85's Avatar
Demonic85
I finally got the cover off, what a relief! I had my neighbor come over and help me. He got underneath the car with a long piece of aluminum pry bar (it was over 1" thick!) and pryed the bottom of the cover up while I used a steel spud bar to pry outwards and it popped off. The cover itself is relatively not too bad. I knocked out all the dents with a hammer and sprayed it with some new paint, looks brand new
Its a good thing I decided to replace the timing set cause once I got in there I found that the chain had a LOT of slack in it. I didnt bother to measure as I knew it was bad (over 1/2" easily). The cam gear had a big crack in a couple of places that went all the way through, heres a pic with arrows pointing towards the cracks.
Old Apr 18, 2008 | 12:47 PM
Frizlefrak's Avatar
Frizlefrak
Glad it finally came off. Yep, looks like a good time for a new timing set. I replaced mine at 140K and it ran like a completely different car afterward. More low end power, better mileage, stronger vacuum, smoother idle, better sound....just all around better running car. I had a ton of slop in the chain and was losing a bunch of timing advance.
Congrats on the victory...
Old Apr 18, 2008 | 07:06 PM
86PACER's Avatar
86PACER
Yes, 85's came with those crappy nylon gears. I think the switched to iron in '86. So what was holding the timing cover?
Old Apr 18, 2008 | 11:04 PM
dave_85's Avatar
dave_85
If your 85 is like mine, you will never get the cover back on without lowering the oil pan. I just did a cam for the second time and it was easy to get back on with the oil pan lowered. The first time I did it I put in a one piece blue Fel-pro oil pan gasket. So this time I didn't have to replace it. I just pulled all the bolts except the back 2 that I just loosened and dropped it down. I didn't even need to remove the oil cooler water pipe.
To Timing Cover
Old Apr 18, 2008 | 11:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
make sure the edges are arrow straight, if they are the slughtest bit tweaked it will leak. remember to seal the corners up good as they like to seep there.
Old Apr 22, 2008 | 05:10 PM
Demonic85's Avatar
Demonic85
Cant get that **** back in there
Do I really have to mess with the oil pan?
Old Apr 22, 2008 | 05:21 PM
dave_85's Avatar
dave_85
I struggled with mine for a few days before I gave up and did the oil pan. Don’t waste you time with the 4 piece gasket or a floppy black one piece. Get the Fel-Pro blue one piece gasket. It has steel in the straight sides and it is easy to line up. It’s a pain to get the oil pan off if you have the Z51 opt. with oil cooler because you need to drain the A/F and remove the water pipe that goes under the oil pan. If you still have the big starter you need to remove it also. Enjoy.
