Electrical Problems!! Common Denominator??
• When I turn off the ignition and remove the key, a ticking sound coming from the area underneath the glove box.
• When I turn off the ignition and remove the key, the radio continues to play.
• The high beam lights don’t work. The switch lever doesn’t have the normal feel for this type of switch.
• The horn doesn’t work.
• The AC/Heat don’t work. At best, “luke warm” air is blown from the heater. The windows don’t defog at all. The AC doesn’t work at all. Sometimes antifreeze can be smelled, no signs of a leak can be seen.
2. Normal there is an accessory delay on these cars should go off when you open the door.
3. Yous should hear a click when you pull back the TS stem when the high beams are turned on. If not it may be a bad switch. PITA to fix
4. Check for voltage at the horn plug. If you have replace the horn if not check the relay under the hush pad and work back.
5. You need to elaborate what HVAC controller you have. When the AC is turned on the clutch on the compressor should engage. When defrost is on the same.Heater core might be bad/bypassed it is connected under the surge tank look at the hoses around there.
You need to get the factory service manual form Helms web site or ebay for your car if you want to work on it.
